how to measure a comm >
Old 08-15-2004, 12:55 AM
onnetz's Avatar
Default how to measure a comm
how do you measure a comm?
onnetz is offline
Old 08-15-2004, 01:00 AM
Trader Rating: 28 (100%+)
take it out of the can/endbell and put a dial caliper over the commutator.
Scott Fisher is offline
Old 08-15-2004, 01:15 AM
onnetz's Avatar
thanks... I had a feeling it would be somthing else to buy...
onnetz is offline
Old 08-15-2004, 01:19 AM
MrRolla's Avatar
Trader Rating: 30 (100%+)
Just get a cheap pair of plastic vernier's
while we're on the subject at what size would a com be ready for the bin??
MrRolla is offline
Old 08-15-2004, 01:32 AM
Trader Rating: 55 (100%+)
6.83mm
tones is offline
Old 08-15-2004, 01:43 AM
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by tones
6.83mm
Man thats playing with fire with a comm that small... I usually never go below 7.0mm
-Dave
JDM_DOHC_SiR is offline
Old 08-15-2004, 08:45 AM
Registered User
What exactly can happen?
Desolas is offline
Old 08-15-2004, 11:49 AM
the segments will come apart or start chipping off of the comm and it can ruin the end bell and also lock the motor up. let alone cause you a big head ache especially during a race
crazymechmow is offline
Old 08-15-2004, 02:12 PM
jeepnyy's Avatar
-Dave
Corecctamondo !!!!!!...I never go down that low anyways. Always use a digital calipher. Ebay have one for less than 20 bux.
Henry E.
jeepnyy is offline
Old 08-15-2004, 03:13 PM
SalvadoriRacing's Avatar
the min. (safe) size is 6.86mm or .270in
SalvadoriRacing is offline
Old 08-15-2004, 10:58 PM
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
When you're measuring with the digital calipers, make sure to measure the top and bottom of the comm to make sure your lathe is cutting true.
Jon Kerr is offline
Old 08-16-2004, 06:27 AM
N4S
N4S's Avatar
Default Run em' till they explode !!!!
If you have ever run one down to or below .268in. the motor is the best its ever been . usually the last run of a arms life is the best. I have really noticed this with the monster stocks
N4S is offline
Old 08-16-2004, 12:07 PM
in engineering terms a micrometer would be best and you should check the dia. at the top middle and bottom and record the difference.
if u had a dyno as well u can check how its effected performance.
trf racer is offline
