Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Picco 2011 TORQUE onroad engines >
Old 08-21-2011, 01:46 PM
  #346
MugenDrew's Avatar
Trader Rating: 36 (100%+)
Originally Posted by walo
Okay. What size header did you use with the 2033? Are the IDM Picco/Mega based?
I used the header that came with the kit. I have not run the engine at Kraceway or Homestead yet, but am very happy with the pipes performance with this engine at Arcadia. They are Picco based. www.idmtuned.com or www.teamshepherdamerica.com for more info.
Or check out the I.D.M. engines thread here on rctech.
MugenDrew is offline
Old 08-21-2011, 05:32 PM
  #347
Trader Rating: 28 (100%+)
Regarding the .12 engines: Does the new Torque use the same rod as the Evo 4? If its not the same, does the old rod fit?
Scott Fisher is offline
Old 08-21-2011, 06:55 PM
  #348
GMartinez's Avatar
Trader Rating: 91 (100%+)
Both engines have different parts # for the con rods so it might not be compatible but will get u some confirmation on it
GMartinez is offline
Old 08-21-2011, 07:22 PM
  #349
Thanks.. I knew they had different part numbers but not sure if they are interchangeable.
Old 08-21-2011, 07:24 PM
  #350
GMartinez's Avatar
10-4 Scott they look identical but it also u never know
Old 08-21-2011, 07:28 PM
  #351
GMartinez's Avatar
Walo ignore it Drew chews to much tabky & Im glad your happy with it Hey Drew did you check the results looks like you got out motored by a stock picco torque
It would of been worse if I did not have some bad pits got stuck on a board for 2 laps
http://www.rctech.net/forum/attachme...ces-round3.txt
Old 08-21-2011, 07:52 PM
  #352
walo's Avatar
Thanks.
walo is offline
Old 08-21-2011, 07:57 PM
  #353
walo's Avatar
, you guys are too much. I just to wanted to know how some racers who tried the Picco line felt about the power of the 7 port. See you guys at the nationals .
walo is offline
Old 08-22-2011, 02:10 PM
  #354
MugenDrew's Avatar
Your trippin, trippin bad. See up top where it shows Drew as 2nd.
There was know race for excusses. I know your just ballistic, your so fast the computer can't even keep track.
"It would of been worse if I did not have some bad pits got stuck on a board for 2 laps" maybe you don't need a EDO mod with a ceramic bearing?
Don't worry I'm sure your gonna smoke me at Homestead and you can rant and rave all over here.
Old 08-22-2011, 02:22 PM
  #355
Default Picco Site
Finally Torque by Picco site up and running now!
For Torque engines and parts go to:
www.kevcoracing.com
spdmkr is offline
Old 08-22-2011, 03:11 PM
  #356
If you have a sedan rod for the Torque, can you throw it in your bag for the GLC. If I need a rod I will gladly pay you for it.
Old 08-22-2011, 04:50 PM
  #357
GMartinez's Avatar
No ranting n raving your the 1 who exaggerated the fact with your comment
Old 08-22-2011, 04:52 PM
  #358
GMartinez's Avatar
Scott all I have is rods for the 21 in my arsenal
Old 08-22-2011, 05:33 PM
  #359
All good. Kevin contacted me and is sending 1 to Rafael on my behalf.
See you in Toledo.
Old 09-05-2011, 12:32 PM
  #360
wingracer's Avatar
Trader Rating: 24 (100%+)
Ran a tank through mine at the club race just to get it tuned in. God you got to love a Picco's bottom end. Torque is an appropriate name
wingracer is offline
