Serpent S411
#5896
I guess we will have to wait for the answer from Johnny Wishbone..
Nick K
Nick K
#5898
[QUOTE=Benzaah;12487695]
FWIW I would not recommend the new spool as it chews blades and if you miss changing them out the driveshafts chew up the opening as its not hardened very well.
The new motor mount on the other hand is awesome. It can only run in flex mode as there are no mounting points for the stiff leg of the original mount.
I used the new spool first time in Super Stock car last weekend indoor. It seems to work fine. I only got maybe 5 runs with the car, but the wear of the blades was minimal. I did not use the blades that comes with the spool. When I compared the blades with the stock part they where not totaly same. Very strange, not a big difference hardly noticeable but next to eachother, the one that came with the spool was "less material"
#5899
vta gearing?
i run vta and usgt with my 2 s411 cars my question is about spur gears and adjusting motor. to get my car in the 3.5 to 4.0 gear ratio i am unable to use the holes in spur gear to tighten motor screws.is there a chart somewhere to help guide me in setting up gears so i know what spurs and pinions will work so i can adjust motor screws through spur gear holes?
#5900
#5902
#5903
Hi Guys. I picked up a used Eryx a few weeks back. I have totally stripped and cleaned and rebuilt the car. The car was basicly new when i received it.
My question is, i have taken apart the shocks, cleaned and put new oil in them. I have set them up for zero rebound. but now they seem to squeek???? only one is completely silent? why is that and what do I have to do to fix the issue?
Nick K
Nick K
No additional parts will be required to change out the mount, and the different inner legs are nice for tuning adjustments. NOTE! the mount is 1mm lower at the idler shaft mounting point, so if you run the screws in that part of the top plate you'll have to use a 1mm spacer to make up the difference or the top plate will be tweaked. (only if your upgrading from a older S car)
Just check the orientation of the split blocks for a mixup.
#5904
The rear split blocks are 0.0's, which I'm pretty sure are symmetrical? I'm considering putting a 1.0 on one side to even it out though.
#5905
#5907
Hi Johnny. Ill take the shocks apart and see what type of meterial the piston is. I used trinity oil in the shock..
Nick K
Nick K
#5908
Is there any white belts for this car
#5909
serpent s411 project
Im about to start a serpent s411 project and would like to get some recommendations for a brushless motor and esc. What would you guys recommend?
