Serpent S411
#5851
I had my worst state titles ever this weekend just gone. On an extremely tight boarded asphalt track I managed to wreck 2 bottom decks, a top deck, a steering rack, 4 sets of front arms, 3 pair of knuckles and 3 drive shafts. This is more parts than I've chewed up in 2 years running the car. DNF 4 out of 6 qualifiers and both b finals. I had a 4th and 7th in my good qualifiers Surprisingly with all this carnage I did not bend any bulk heads or toe blocks.
FWIW I would not recommend the new spool as it chews blades and if you miss changing them out the driveshafts chew up the opening as its not hardened very well.
The new motor mount on the other hand is awesome. It can only run in flex mode as there are no mounting points for the stiff leg of the original mount.
Lastly, Is anyone aware of an updated kit coming soon? I'm in need of a new one!
Victor Wilck had the fasted recorded speed with 116 km on the straight, that was faster than the 1/8 Nitro cars. I was crusing down in 100. He is also running the TP 4.5 I wounder if he uses nitro in the motor.....
#5852
This weekend we had the last race of the Belgium nats.
Grip was low and everyone had trobble with the rear end stepping out.
The trick that did the job was take out the rollcenter spacers in the back.
and camber at 0.5°.
I can recommend everybody that drives a parking lot track or a low traction track to try this. Don't forget not to change ride hight and downstops.
and camber at 0.5°.
#5853
One thing to note about the plastics, at least certainly on the wishbones, is that serpent made a running change to the medium arms for the Eryx. They kept the same part number, but revised the arm thickness, webbing, and material type used, which made the new medium arms a lot stiffer than the old ones, and less flexible than the old hard. With the thicker webs, they are also a lot more durable than the old Hards...
Biggest issue is that there is old stock of mediums still around. You want to get the newer header cards (the black/grey design) rather than the old ones, and the arms are clearly marked with an 'M'. You can also tell by the webbing nearest the inner hinge pin, as this curves round more between the two hinge pin holes.
Deffiently worth trying out for a better arm solution.
Regards
Ed
Regards
Ed
I was at my first Swediah Nationals this weekend. I had also some ruined equipment. Two qualifying heats in rain on Saturday that took the life out my waterproff reciever and speed controler, motor and bearings in the car. After third qualifying I was 10th and I had Victor Wilck and Alexander Hagberg in 11th and 12th positon.... that was fun on paper.. but they did not run in the rain so they had only one heat at that time... In the end they eneded up first and second. I was in the other end.....
#5854
and camber at 0.5°.
and camber at 0.5°.
#5856
this is the setup.
https://www.dropbox.com/s/ivalbol2cn...20zwevegem.pdf
Info on the new car, there wil be a new chassis and topdeck
#5857
I can't see the setup, it tells me that the webpage doesn't exist.
Great to hear new chassis as I have some wear on mine and maybe this winter I will change it
Regards
Regards
#5858
#5859
#5860
#5864
Anyone know if there is a low friction WHITE belt set for the serpent
#5865
Hey guy's
Need a new servo for my serpent, what do you guys recommend? My Futaba s9550 bit the dust after 7 years. Should I go low profile or regular size...I am going to try Savox servos this time around. Read really good reviews on them. How is their low profile for the s411TE?
Also has anyone upgraded their s411TE to ERYX? Don't want to spend money on a new car at the moment. Any good parts to order for te S411 that's worth it from the ERYX.
Thanks guys,
Thanks guys,
