Like Tree16Likes
Serpent S411
Old 09-17-2012, 10:35 AM
  #4201
Johnny Wishbone's Avatar
Anyone know if the original shocks would be considered "emulsion" type shocks?
FYI, I have run the plastic Xray diff gears (10 tooth) in the Serpent gear diff without issues as well, although the Exceed gears feel a little better.
Johnny Wishbone is offline
Old 09-17-2012, 12:04 PM
  #4202
Trader Rating: 23 (100%+)
I don't think so mr wishbone. Emulsion would suggest that air is allowed to mix with the shock oil wouldn't you say?
Btw: where's Mr. Crisp these days?
pcar951 is offline
Old 09-17-2012, 12:42 PM
  #4203
Hi Jim, I know nothing of emulsion type shocks, but thinking of the TC5 type shock that used the cartridge, I thought this was similar to the serpent older shock, although, I have no idea how the air gets into the TC5 shock to create the emulsifaction? If you know please enlighten me.
Last word from Martin was that he had taken on a big work project that was taking him away from RC for quite some time.
BTW are you doing the IIC this year?
Old 09-17-2012, 12:58 PM
  #4204
dawgmeat's Avatar
Just do what I did, replace the shocks with TRF's and change out the blue caps to the exotech gun metals and be done with them
dawgmeat is offline
Old 09-17-2012, 01:12 PM
  #4205
After reading the Associated build info on the B44 shocks, I see that it has nothing to do with the cartridge design, my bad.
Thats just it, always looking for that killer shock setup, so maybe there is something better than the TRF's too, although I see that they where playing around with emulsion shocks on their cars as well...............always looking
Old 09-17-2012, 02:18 PM
  #4206
cwoods34's Avatar
I'm happy with TRF shocks on mine..... Using the blue mounts for them pushes the shock a couple millimeters further from the arm and tower than stock, but it hasn't affected anything.
cwoods34 is offline
Old 09-17-2012, 02:48 PM
  #4207
rdlkgliders's Avatar
Trader Rating: 21 (96%+)
Maybe we will all be running these.
AME T-SHOX
rdlkgliders is offline
Old 09-17-2012, 02:50 PM
  #4208
I always run my cars with a 1mm spacer behind the shock, top and bottom, so I would think what your describing would be perfect.
Its not the shock design issue as much as a certain feel that I'm looking for on the shock, so even though TRF has a nice shock and I believe with the nylon pistons the RCM (or the RCXX) shock can be made just as smooth, its the actual dampening and rebound feel that I'm looking for. So I'm starting to look at other alternatives, one being, emulsion type shocks, don't know much about them, but perhaps worth looking at. I dunno?
Did you get a chance to test out your servo mount yet? My version of the low mount is hanging on pretty well so far. We had a track change on Weds that I didn't make it out to, but raced on Sunday, so needless to say, I put it through some pretty high stress tests, without failure. LOL
Old 09-17-2012, 02:58 PM
  #4209
AME T-SHOX
I looked at those as well, interesting design, the only advantage I see with them is the support at the top and bottom so there is very little rod deflection during the extreme stroke of the shock. I think those would be a good application if one where getting into some very heavy shock oil setups, where the drag force of the piston begins to put uneven pressure on the shaft, or different sized holes in the same piston.
Old 09-17-2012, 04:09 PM
  #4210
cwoods34's Avatar
Yeah, it felt pretty good. Even with some barrier/traffic bumps the steering stayed exactly where I set it. I didn't get a lot of track time, but I hope to burn up some packs this Friday.
cwoods34 is offline
Old 09-17-2012, 05:06 PM
  #4211
You can create an emulsion type shock simply by cutting the bladder on the rcm shocks(retaining just the outer ring, much like an oring). And using shock tops with no hole drilled. The cavity in the top should contain some air as you bleed the shock, and will mix once the shock is pumped a few times. In offroad this is preferred on smoother tracks, where bump damping isn't as much a concern. In my experience, the rebound will be a bit slower. Just be sure to bleed fully, as hydro-lock is possible with too much oil.
jsorwell is offline
Old 09-17-2012, 07:52 PM
  #4212
Gary no IIC for me this year, way too much happening at work these days. Only got 4 days off for summer vaction this year...bummer!
pcar951 is offline
Old 09-17-2012, 08:56 PM
  #4213
Awesome, thanks, I see more testing in the future. I'm guessing the Associated guys went to the TC5 shock because the top cap has the bleed screw option, which would make the process a little easier.
That's all I've managed to take off this year as well......makes for a long summer, if not IIC maybe the Birds.........
Old 09-17-2012, 09:05 PM
  #4214
damage's Avatar
Gary,
Can you share your current carpet setup for your S411? Are you running the v2 motor mount and 2.5mm chassis, as well have you upgraded the diffs and shocks too?
Have you got the car where you want it and consistent? I remember some of the struggles we where having at the Regina leg of WCICS last year.
Warren
damage is offline
Old 09-17-2012, 09:07 PM
  #4215
duckman996's Avatar
Trader Rating: 14 (100%+)
He's gone back to racing 1:1 cars as well as a new work project has taken him out of RC for a while. He'll be back.... they always come back - LOL.
duckman996 is offline
