Like Tree16Likes
Serpent S411
Old 09-13-2012, 05:55 AM
  #4171
Originally Posted by Geberit
Did you try the nylon spool also with modifide motors? Can it handle the power?
Here in Brazil we use 10.5 motor and nylon spool survived 4 batteries
Pickthall is offline
Old 09-13-2012, 05:57 AM
  #4172
Toughbeard's Avatar
Not yet. For some odd reason people love buying my stuff. I need to build a new car for myself. But I am going to take one to the track next week with Mustafa and test on his car.
I think it can handle the abuse at least for a day
Toughbeard is offline
Old 09-13-2012, 06:45 AM
  #4173
Geberit's Avatar
In this case I wont even try a 4.5 motor
Geberit is offline
Old 09-13-2012, 08:21 AM
  #4174
Toughbeard's Avatar
I ll try it for you and let you know. got 15 in stock anyways
Old 09-14-2012, 06:15 AM
  #4175
Default Spur and Pinions for S411
Which brands do you suggest?
Needs to be 48DP
Have to make FDR3.5/4.0/4.25/4.5.
Don't mean how many teeth, I mean which brands would fit and are durable?
Kensei is offline
Old 09-14-2012, 06:31 AM
  #4176
Toughbeard's Avatar
Needs to be 48DP
Errrrr Serpent
Old 09-14-2012, 07:22 AM
  #4177
TimPotter's Avatar
Trader Rating: 15 (100%+)
Couple of pics of the S411 sport...
Attached Thumbnails Serpent S411-update01.jpg   Serpent S411-update03.jpg   Serpent S411-update06.jpg
TimPotter is offline
Old 09-14-2012, 07:26 AM
  #4178
Trader Rating: 38 (100%+)
Yup, Serpent spur gears would be my choice for 48 pitch. I'm pretty much covered on them as I was working on my off-road stuff shortly before ordering spurs and ended up ordering every 48 pitch spur they had. After a bit of measuring and checking I found that the latest CRC spurs for 12th scale fit the car as well so mine is now using an 88 tooth CRC spur. I did have to use 1mm spacers on the screws as the CRC is thinner in that area and also a button head on the rear motor mount because the CRC teeth are a bit wider. Overall everything looks good though and I will be driving it this weekend.
linkless is offline
Old 09-14-2012, 09:43 AM
  #4179
Johnny Wishbone's Avatar
Tim, whats the specs on the top plate on the Sport? It looks like a glass plate, will if fit a regular S411? How thick is it?
Any Serpents going to IIC?
Johnny Wishbone is offline
Old 09-14-2012, 09:51 AM
  #4180
TimPotter's Avatar
I'll take it off and make sure it lines up, but I am 95% it will. What is differerent, is that there is no hole even drilled for the motor mount screw.( to be clear.. the hole in the top deck., but it is not in the mount itself. )
I though people would have picked up on the split blocks in the rear...
Old 09-14-2012, 09:58 AM
  #4181
I did see those, how are they secured to the chassis? Also are the shock bodies plastic or aluminum? Are they rear dog bones just a different colour or material as well?
Old 09-14-2012, 10:07 AM
  #4182
cwoods34's Avatar
Hmmm, FRP upper deck and split blocks would be worth testing....
Also, aluminum rear axles for weight savings...... unless Serpent already makes them?!
cwoods34 is offline
Old 09-14-2012, 10:09 AM
  #4183
TimPotter's Avatar
rear dog bones...
plastic shock bodies...
the chassis has an extra hole for it...
Old 09-14-2012, 10:14 AM
  #4184
cwoods34's Avatar
rear dog bones...
I had a T3R (FRP upper and lower)...... the material worked pretty well on carpet. I'd be tempted to at least buy the lower deck to try out and have a "template" to drill for using the split blocks on the regular chassis.
cwoods34 is offline
Old 09-14-2012, 10:27 AM
  #4185
TimPotter's Avatar
When I showed the car to everyone at our local track... they were like...
" Wow, this thing is stiff "
I would hazard to guess that a new chasiss will be along soon with aluminum bocks.
