Serpent S411
#4021
Interesting, as you say perhaps it went far to soft for your track conditions causing other handling issues on the side. Still its another tuning option that may work somewhere some time. I recall doing testing of V1 VS V2 mount and found that V2 felt like it made the car have a slight torque steer issue, now I run the V2 almost always and suspect that the weird feel could have been the gear diff more than the motor mount.
At a minimum, if you run on carpet, get the hard arms. You could opt for the whole hard option parts but the arms have the greatest impact on the car. The 2.50 top deck is really nice (followed by the 2.50 chassis, I have modified my stock 2.50 to same widths as all the newer chassis). The V2 motor mount is a good option as well. You'll probably need some .5mm lower shims for lower rc adjustment. Also a selection of shock oils and diff oils. The rest of the kit is pretty solid. Check the Petit RC site for setups, quite a few carpet ones on there.
Nice to here, twice the car for half the price.. The active rear toe is something I looked at a while back on the 411, I think it could be done without a lot of work, but not sure if it would be worth it, maybe more of a asphalt big track thing, where on our short carpet tracks the short straight may not really be worth the effort.
I would agree, its hard to give good solid setup help when your not actually there to see what the track is doing and how it effects the car. Even for myself, sometimes what others observe, isn't what the driver is feeling or seeing, so all you can do is give general ideas, but never take it as rock solid advice, and be prepared to change your setup. Ultimately you have to drive the car, and if it feels good to you that is what counts, no matter what the setup book and the experts say. Most times what information that is given is what worked for them in that situation, even Martin Crisps setup book last sentence says you're setup may differ from what is suggested.
do you have a link to that site
Are people running diff on both ends or spools and oneway any of that?
Last time i raced rubber tire sedan I had a Decked out TC3 in 99
Thanks for a list of items and the link when you get time
#4022
On carpet I like a front diff w/OFNA locker.... on asphalt so far I've liked a spool or diff w/putty (a bit tighter than OFNA locker). If the track is really small, 300k-500k in the front diff is awesome.
#4024
Hey Marcos Do you work for desoto? P.S the car looks great.
BCDK tell Rasmus he should chime in more, he was lurking around the thread awhile back.
I see a lot of spring and diff talk, and a lot more people coming in with info on setup. It is great to see racer support increasing.
I have been mostly using white, grey and black in different combo's for awhile now. I think I need to check in to the ride springs or try the x ray springs (I hear mixed reviews on the new progressives) I run low cst in the rear diff when traction is low as low as 500 cst lately or I throw in the ball diff to find some easy adjustability and quick traction.
#4025
Super Moderator
#4027
http://www.petitrc.com/reglages/serp...rpentS411.html
you sure you researched these forum pages?
#4028
It has taken a while, but the S411 is really starting to gain momentum. We have more 411's in South Florida then any other eTC. It has been tough, as we had a bunch of s400's, so much so our local track was a "Snake Pit". The problems that Serpent had with the parts supplier really caused some grief with racers. I am so happy to say, parts have been easy to get, and if anything is not in, it is in stock in 2 weeks or less.
We have 15+ guys that run the car at our track.... for Club races and practice...
We have a couple local shops that stock s411 parts and if you cannot get them from the local shops SerpentAmerica is real easy to get the parts from.
#4029
car comes w/ gear diff & spool for good reasons as do all major comp brands
#4031
New cutting rear shock tower
#4034
looking at getting ready for our winter season . What does everyone think . Will there be a new kit for this winter ?
#4035
This is one cool car .
