Serpent S411
#2806
If you run the rack with the arms in the stock location the rack is high and it really raises the angle of the link to the steering hub (big bump steer). You can probably adjust it by shims, but can't get it out completely. If you run them flipped you can get a level link.
It also makes the link to the servo at a little nicer angle.
If you get the right size ball end wrench you can still change the ackerman spacers without a lot of dis-assembly.
It should be noted if you run the V2 this way, to get full lock on the steering, you will have to file the corner of the tape holder just slightly for the arm clearance, but this won't weaken the holder.
I don't think it being a lowered mass on the chassis has any bearing on this.
#2807
I forgot to say that the piece is made of kydex, its about 2 to 3mm thick. Its just thick enough that any back movement of the bumper will hit the bulkheads well before the chassis snaps.
#2808
I can say I have 2 cars and the one with a lot of run time on it is much freer yet I can't find the difference between the 2 that would make one better than the other, just track time.
The Serpent bearings are pretty good, although I did have one that felt looser in the race area, enough that it made for some inconsistent chassis settings. But only one bearing out of 2 cars again.
#2810
Nope, but its there if you need it.
#2811
Go to 3:45. do this both front and rear. once done, undo your pinion and without the shims it will only turn once but with 0.2mm shims it will spin a few times
#2813
#2814
MODDED DECKS
HERE ARE THE MODDED DECKS I JUST DID. THE ONE ON THE LEFT IS STOCK. AND THE 3RD FROM THE LEFT IS THE FLEXY DECK. THE OTHER TWO I DID.
#2817
kinda
no i used the outer lines of the deck and marked it with a perm marker. if you notice, the two really flexy decks are different. one will allow the whole car to flex more and the other will allow the rear to flex more. just with the placement of the cuts. now, i have not run any of them yet, but i will this coming week during practice and race day. i have two cars built so i will be able to test several different combos. i have one with the 2mm chassis and one with the 2.5mm chassis. so i will try these decks on both cars on our low traction carpet track. its tight and its currently technical.
and to answer, these are all 2mm decks.
#2818
if you follow the outside lines of the deck with a sharpie, it will make nice lines for the dremel. i did the one deck that looks like the flexy shown all by hand with the dremel and a quick file job.
#2819
Does anyone have a 2mm chassis they will part with?
I had a pretty good first day with the snake today finished 4th in a main behind the guys that are just faster and finished ahead of guys I am often behind.
Not bad I don't claim to be the fastest. The car was really fast in the flowing sections and good to drive, a little loose out of the tright stuff and are track is really tight and low to low mid traction.
