Serpent S411
#1831
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
im hving issues with rattling while the steering on power. im horrible at trying to explain in details so i made a quick video of the problem..
as the shows no top deck, the problem happens when the top deck is screwed on as well. as the video shows, it happens when wheels are installed
when the wheels are off, it doesnt seem to happen at all
any ideas? thanks
+ YouTube Video | |
+ YouTube Video | |
any ideas? thanks
now on a side note i ordered my kit s411 kit today.. jeremy
#1832
Benzaah and others,
Thank you for the quick replies and advice. i rarely do i ever run my car without load, i chose to do so in this case to show my problem and even then the throttle was at 50%.
Thanks again with all the help and i will be lookin to get the gear diff, then the DCJ later on.
again, thanks for the advice and clarification..
#1833
where can i order the s411 le, seems like only rcmarket has a preorder, is there some in usa, or canada have these for sale i want to place an order so i can get one, thanks
#1834
any ideas? thanks
+ YouTube Video | |
+ YouTube Video | |
any ideas? thanks
Doesn't matter which car, Tamiya, Yokomo, Schumacher and Co. - all doing that!
Only one Way to fix that - Double-Joint CVD's ...
#1835
I'm getting a weird setup issue with both of my cars. Was puttering it around on some tiles (very low traction) with regular tyres and noticed that from a standstill or a slow roll, full throttle will make the back kick out and to the left.
Any ideas what this could be? Unbalanced car? Where should I start looking? Both were on kit setup.
#1836
The reason the car is chattering is you have a solid axle with a a single cvd joint, which creates a angle phasing issue. There are two solutions to fix this issue is dual joint cvds or if you run a front diff. This is why in big cars they do not do this, it affects the handling and unneeded stress on the parts.
#1839
the auction starts at 28 nov?
#1840
Hi VexVegaz.
It could also be the pins in the 19 teeth pulleys at the spur. The pins, which go through the spur axle and hold the pulleys. The hole in the pulleys are slightly too big for the pins. Fill in something at the pins - like a tiny puttygum ball (only 1 mm thick) at each pin end.
I had a noise like that. Wenn there was no weight on the belts, then I had no noise. I had exactly the same issue years ago in a Corally RDX Phi.
Try it. It is done in a few minutes. Mayby that is your problem.
This issue has been discussed earlier here in this forum.
Benzaah and others,
#1841
#1842
As stated already, the rattling is because of the CVDs getting angled too much. Nothing else. Every car with spool has this phenomenon to some degree.
This is just a theoretical problem though, since a properly driven/properly set up car never reaches those angles, except maybe in really tight hair pins and slow sections. At low speed, this rattling is negligible (when driving). If you need to turn the steering that much in order to get around the corner, your car is not set up properly. This extreme angling of the CVDs will also make the rear end feel loose (more than necessary). I usually never turn the steering more than 85%. It's sufficient even for very tight tracks.
Solution: Dual-joint axles or differential. A gear diff with 500k oil works very well in every condition.
Best,
Michael, Serpent International
Best,
