New 1/8 on-road "XR8" >
Old 07-11-2005, 11:25 PM
  #556
Roger's Avatar
Originally Posted by Darthswan
Anyone know the set up of there cars?
I'll see if I can get in contact with one of them and post thier set-up asap for everybody.
Roger is offline
Old 07-13-2005, 09:41 AM
  #557
Roger's Avatar
Default XR/8 Set-Up for Rams Club ( Mission College )
This is the set-up that I got from Jimmy Deprez afew days before the Rams race. I know he ran this set-up and if there are any changes, i'll let you guys know.
FRONT SUSPENSION:
Track width: 252.5mm
Ride Height: 5.5mm
Camber Angle: -2.0 degrees
Toe Angle: +1.0 degrees
Rebound Stop: 1.0mm
Front Shock mount position: Middle
Caster: one BIG and SMALL clip up front and one BIG and MEDIUM clip in the back.
Steering Ackerman: B block with turnbuckles mounted towards the front of the car ( There are 2 positions on the steering ackerman block ).
Front Sway Bar: Flat position
Ecentric Roll Center bushings: Both upper and lower bushings mounts in the downward position.
( On the lower front arms, set the wheelbase to its SHORTEST setting. There is ONE caster clip that we use to either lengthen or shorten the wheel base. )
FRONT SHOCKS:
Shock piston: 1 hole piston ( piston hole was enlarged )
Oil: Mugen 90 wght.
Spring: PRP front Yellows
REAR SUSPENSION:
Track Width: 264.5mm
Ride Height: 6.0mm
Toe Angle: -2.5 degrees
Rebound Stop: 8.0mm
Rear Shock Mount Position: All the way down
Rear Sway Bar: REMOVE ( No swaybar )
( Use a 3mm shim under the upper arm that mounts to the rear hub carriers ).
REAR SHOCKS:
Shock Piston: 2 hole piston ( piston holes were enlarged )
Oil: 90 wght.
Spring: Rear mugen white
TIRES:
Enneti 37's, Jaco 38's, or Ellegi 38's
Front diameter: 66.0
Rear diameter: 73.0
( use a seven millimeter split )
DRIVE RATIO:
48/44 SPURS
16/21 PINIONS
OVERDRIVE PULLY: 26T
I will try to have either Jimmy or Kevin post any possible changes they may have done to the car.
Roger is offline
Old 07-13-2005, 09:46 AM
  #558
Default Set-up
Roger,
Good to see set-up info. That was Jimmy's car, correct?
Rich Browne is offline
Old 07-13-2005, 10:03 AM
  #559
Roger's Avatar
Browne: I'll contact you in regards to that. Thankyou.
Roger is offline
Old 07-13-2005, 11:16 AM
  #560
Roger's Avatar
Originally Posted by Rich Browne
Roger,
Is that Kevin or Jimmies set-up?
Jimmy's set-up
Roger is offline
Old 07-15-2005, 10:20 PM
  #561
Ran my car for the first time today, this thing screams. Have a couple of adjustments to make, but I like what I see. And the VZ-R II, the engine is unbeleivable. The just paved the street on my block. I'm like a kid in a candy store.
My question:
What the advantage to having a Rulon shoe?
Thanks.
Darthswan is offline
Old 07-16-2005, 10:07 AM
  #562
Trader Rating: 79 (99%+)
Default rulon shoe
My question:
Thanks.
The clutch shoe grabs earlier, and more consistent. I am glad you like the car and the VZ-RII. MY last race, I destroyed my crankcase, shearing off the exhaust flange. My car is a heap of parts right now....
Raul Garcia is offline
Old 07-16-2005, 01:03 PM
  #563
Ouch, how did that happen?
I think I'm going to have to pick up a couple of add ons.
K
Old 07-16-2005, 08:51 PM
  #564
im a newbie to "THIS" type of car, but i bought the rtr the other day and ran 2 tanks through it today, i love it... "the 27 motor has to go",
i live in newark,nj and a guy came in my lhs with a mugen "i swear these cars are set up almost the same.." i really dont feel like im cheating myself at all"$399.99
WOW... should've goten one of these a long time ago
plug......rchobbies in hillside nj
epicbloodline is offline
Old 07-18-2005, 05:26 PM
  #565
Default problems
K
Well, I have been experimenting with Li-poly packs, and decided to use no voltage reg on the receiver. This in turn fried two servos, not knowingly, the second decided to take a dirt knap at the top of the main straight 200'+ long. I turned the wheel and nothing happened but hitting a cement filled tire.... I will sort this out though.
Old 07-19-2005, 09:17 AM
  #566
R40Victim's Avatar
Ah man...sorry to hear that. Mine suffered a similar fate, but only hit a 1x10 piece of unsecured wood...almost no damage. After reading the advantages and disadvantages of Li-Po power, I decided it wasn't worth the trouble...
R40Victim is offline
Old 07-20-2005, 03:21 AM
  #567
Default lipoly
R40, ther are no disadvantages running Li-poly's. They are lighter, stronger, and last longer(shelf life), than anything else out there. I think with the Novak Regulator, is the key
Old 07-20-2005, 07:08 AM
  #568
duneland's Avatar
That's right! But you got lucky finding one that will fit in the space provided.
If they hadn't discontinued that one, I would have it in my car.
duneland is offline
Old 07-20-2005, 08:14 AM
  #569
R40Victim's Avatar
That's true, and I should have specified, "in my application". I understand the advantages, I even looked into the setup for myself. Like I said, not worth the extra effort for me. I still like the idea, I've become more interested in Li-Po since they're alot more common in recent years. If there was a specific part designed to fit my car and couldn't overpower the control system, I'd be all for it. Oh yah, I'd have to get a Li-Po charger too, just not worth it. If our races were alot longer, then it would be worth the investment.
Old 07-26-2005, 01:14 AM
  #570
hey guys, both my hopped up xr8s are on ebay right now, no time to race, new work schedule, less than a gallon through both cars together.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5989555143
anrkii is offline
