LRP SXX StockSpec V2 ESC
#391
i'm not to up on these lrp speedo's, but can you load the stockspec firmwares onto the sxx v2 competition speedo's?
Cheers
Cheers
#393
guys I have a silly question, how do you set up this esc ??
if tekin RS you use hotwire,, but what about LRP ??
and since I am beginner, which one do you think better LRP or tekin RS ?
I am running TC stock ...
#394
With that said, I strongly believe the LRP will be easier on someone new to the scene as there are far less variables as far as 'setting it up'. Throughout this thread, as well as the SXXV2 setup thread you will find users posting there setups.
Granted with time, practice, and personal feel you will find how you like the esc to be setup per tracks you run on. There is no need for thousands of posts explaining the esc settings and terminology.
Here's a little excerpt from the manual:
You can also find the full manual over at LRP.cc
#396
what's the difference between stock spec and TC spec ?
#398
#400
If you want to be smooth with the tekin you just have to set it smooth...
Lrp is just easier to set than the tekin for begginer in boost classes
#401
17.5 boosted
Hi all..After much testing...and no blown motors..
I have the LRP going pretty quick..Keeps up with the Tekins, hobbywings no problems..
Using the X12, 17.5..Touring car. rubber tyres.
LARGE out door track..190 foot straight...anti-clockwise
3.4.11.1 FDR 4.78 .2 dot insert..Using New REV tech 6000's. 2 fans on motor.
track temp 22deg C, air temp 15deg C, cold cloudy day. after 5mins 4 blinks on esc internal temp/motor. found this to be the better setting for me.
tried 1 dot..Faded way too quickly..
I didnt mind 3.4.11.1.FDR 4.99 3 dot insert...will run this if the track gets hot.
Still fades at 4 min 30sec Has any one else who runs on LARGE tracks found this???
Dont know what people are saying that you cannot use anything but the 4dot Have they tried?????
Next time..going to try 3.4.11.1. fdr 4.5ish with 4 dot...should rip out of corners and hope no fade as not as much timming..But will it have top end?
well see, not to worried about the temps..it WILL be cool.
Not game to use 12 on boost..It killed a motor, D3 in 2 laps...
This is fast and smooth..But Im finding that it fades at 4mins 30 secs.
Motor is not hot. I assume that the battery cannot keep the voltage up. I tried different settings and still fade..
I was told that the LRP motors suck power...
Will try a D3 and see what happens.
#402
Make sure you are not above 5 feel with the X-12. The higher numbers are for other motors, ie X-11, D3 etc. If your X-12 sucks power, it is due to high settings of feel and boost. Also, you are not getting any heat because your timing is so high, the motor will not get going to generate heat. Good luck.
#403
#404
I thought odd numbers should be used for the Boost with X12's ? or is that just for the Feel ?
#405
