rollout help
rollout help
hi guys,
ive checked this ratio/fdr/rollout calculator:
gearwizard
and it says my rollout should be 0.975 is this bad as i thought your rollout should be as low as possible
heres the setup, not actually used cos the car hasnt arrived but this is what ittl be:
spur: 85
pinion:19 or 21
idr: 1.8.1
tire diameter: 2.6
gearwizard
spur: 85
pinion:19 or 21
idr: 1.8.1
tire diameter: 2.6
19/85 24.58mm R/O
21/85 27.17mm R/O
19/85 8.05 FDR
21/85 7.29 FDR
Cheers
21/85 27.17mm R/O
19/85 8.05 FDR
21/85 7.29 FDR
Cheers
thanks im getting a 19t pinion
