Proposed R.O.A.R. rules change
#512
agreed.
we seem to be stuck between 2 extremes, mod where speed is limited by skill and stock/spec which is limited by batteryvoltage.
i would suggest that the transition or tween class be fast enough that skill is at least as important as voltage and rotor strenth.
#513
I race 12th scale and WGT, foam never left!!! It just stayed on in the "better" classes.
I still can't believe that the guys running the most technically overwhelming, and difficult to maintain chassis are so terrified of having to learn how to tune a speedo
My new proposal to ROAR is to simply leave the pan-car classes open speedo, and take the opinion of the majority of the TC racers and go with that. Just please don't EVER make anyone put a 21.5, boosted or otherwise, in a single cell pan car.
#515
#516
It was Dirla I think..........yeah I'm sure it was him
Cheaper on parts for the newbie who can't get a rubber car to handle.....but that's a dead horse
Agreed completely
Agreed completely
#518
Foam is horrible and probably the main reason you never see any US guys winning worlds. That will change soon, im sure- now that we have finally ditched foam.
they do not last longer than rubber= and if you think they do, you weren't running them properly
at least on carpet..
#519
My track is a parking lot. Rubber tires are good for one maybe two heats and then they have little to no traction. Foams have the same traction up untill the foam is gone from the wheel. You just have to adjust ride height. Foams on touring car about 20 for a set, rubber is 40. We also run 10.5.
#520
IF the issue is simply that the profiles can be altered on the fly from "spec blinky" to another profile and back again. This too can be altered with a quick software update. We could simply NOT allow the user to switch from "blinky spec" to another profile WHILE in blinky mode. And THAT update woud once again be FREE!
#521
That's awesome. If you can do that Tekin, then it must be a requirement to mount the RS so you can see it through the bumper for easy Tech.
#522
No biggie though, I just play with TC's. After all these years, I still can't get that into it.
#523
Foam was fine back when the cars were slower. Now, foam (especially mod) comes apart in a couple of runs. Even in 12th they're mowing the tires down so they're only good for a couple of runs. Run harder rubber and you'll go slow.
There are more ways to slow the motors down than just adding winds. The first thing I would do is try a single wind instead of the doubles. What I think we need is less torque from the motors not less RPM.
Something needs to be done to get onroad back on track before it dies out completely... I really don't want to hear about everyone's local track that's doing great. Fact is that onroad is dieing a slow death and it's going to take changes in order to attract new racers.
