who holds the speed record?
#797
Originally posted by burbs
tell me this ajg.. then why do the 3300 mah pack have a much higher voltage on a matcher, then the old 3000mah or 2400mah or 2000mah packs??? it all works in relation....
ive been racing longer then u have been alive.. knowledge and expirience beats anything u have brought to the plate
#800
Voltage into a cell charging doesn't have anything to do with how a cell will perform. I believe mah is a formula of output over time. A higher mah will have either more output voltage or last longer or a combination of both.
Any I think the higher the peak voltage of a cell while charging, the higher the internal resistance of the cell.
#801
okay Ajg.....
Where are you, no....... How much are going to plop down to accquire this particular item? If you can afford private school (I didn't go to a private school) Live out in "Beverly Hills", N.M. , and can afford two of each equipment (check out your sig a complete setup for both your "1/18" monster truck and your micro) Who are you going to pay to clock your car? Sure hope it will won't be your cameraman!!!
Also, I'm going to get a radar gun soon, I hope.
#802
Originally posted by GundamWZero
okay Ajg.....
okay Ajg.....
#805
Read cardboards' quote..........
Also, I'm running a 58 tooth spur and a 33 tooth pinion.
#808
Originally posted by ajg
Keep em coming. It makes me laugh.
what a numbnut!
ajg...for real dude......do you do birthday parties or barmitzvahs? You say the funniest things!
#809
Uh, all I did was post what my cells charge at. Don't go cry now.
this is the second time he told someone not to cry....
believe me, I'm sure those two guys are not shedding a tear on your behalf.
Sounds like ajg is breaking down and is crying himself.
Seriously, ajg, you're not trying to save face, are you? Is that why you're still here? I think that opportunity has long disappeared....
#810
Ok, if his motor is turning at 64,000 rpm in his micro. His car would do 149.5 rpm with no load.
Since there is no way his motor is going that fast
25,000 rpm is 57mph
20,000 rpm is 46.73 rpm
your rear axle is spinning
@25,000 rpm = 14285
@20,000 rpm = 11428
anyone know the tire diameter or circumference of 1/10th scale truck?
25,000 rpm is 57mph
@25,000 rpm = 14285
@20,000 rpm = 11428
