who holds the speed record? >
Old 08-17-2004, 04:42 PM
  #511
GundamWZero's Avatar
Originally posted by studysession
AA's do not put out enough AMP's.
I am running the equivilent (cant spell) of AA rechargables on mine. They are the kind used for building battery packs. On my Mamba Motor which is brushless - they cause a lot of cogging. More or less the batteries suck.
The sub-c's are deisgned to put out more power volt/amps per cell than the AA's.
Have you tried AA NiMH cells? Not Nicad cells. If you haddn't read I have some that is 2300 mah. You standard NiMH cells you race are 3300 and 3600.
GundamWZero is offline
Old 08-17-2004, 05:33 PM
  #512
DaNieL_KuO's Avatar
Originally posted by GundamWZero
www.centuryheli.com
You know I would never thought I'll own a helicopter, cause they cost too much. However, now they are cheaper to accquire. But watch out! Once you wreck them, the price of repair goes up!
you think you just broke an A-arm...........
http://www.neptune.com/users/danielk...lkuo122077.wmv
video of me flying my micro helicopter lol, I sucks at flying it. Its me and my frends messing around in my garage
DaNieL_KuO is offline
Old 08-17-2004, 05:38 PM
  #513
DaNieL_KuO's Avatar
AAs cant handle a modified 540 motor trust me, the AAs wil fry .AAs cant push out 35 + amps, if it did it would blow up
Old 08-17-2004, 08:19 PM
  #514
So then he can't use AA NiMHs.....
Hes gotta lose the weight and gain power, or else he is just pissing in the wind on this......
Old 08-17-2004, 08:32 PM
  #515
DaNieL_KuO's Avatar
I think CP 1300s are good enough.
As far as Weight, its fine.
One thing if he wanted to have less weight, is you could wire up some lithiums paralell and another with it in series. This will increase the voltage , capacity, and amprage.
Old 08-17-2004, 09:16 PM
  #516
ajg
Registered User
ajg's Avatar
cp-1300 cells weigh 35g
2300 mah AA cells weigh 30g
lipoly 830mah cells weigh 42g
ajg is offline
Old 08-17-2004, 09:48 PM
  #517
razzo's Avatar
wow, this thread moves fast...
few questions, GM V12 maxes out at 8 cells. Are there small ESCs that'll go beyond 8? At this point, you can't add anymore cells with out going to a brushless system? Isn't coming up with other cell alternatives kinda moot, since you're stuck at 8 cells anyway? also, may be send your battery pack to a matcher to have it at least zapped for more voltage? Same weight, and even little more voltage will help? Or how about getting rid of the ESC, and going with micro-switch, ala RC dragster? no cell limit, and you can probrably replace the space taken up by the ESC with 2 more cells?
How did you get 64,000 rpm for motor number? didn't think there was a dyno that ran at 9.6V
And how the heck did you spend $1100 already on this micro? It's not like you're using $500 radio and $120 servo? 24K gold plated aluminum parts?
razzo is offline
Old 08-17-2004, 09:52 PM
  #518
Super Steve's Avatar
one lipoly cell has voltage alittle more then 3 nimh cells
2/3SC
35grams X 8 = 280 grams and gives you 9.6v
Lithium 830mah in your example
42grams X 3 = 126 grams and gives you 11.1V
Super Steve is offline
Old 08-17-2004, 09:53 PM
  #519
ajg
Registered User
ajg's Avatar
The GM V12 can handle 10 cells or 12 volts. Also, the cells were zapped.
Here's some of the stuff that I bought for my micro, there's probably more.
Micro cost:
Kit: 100
Aktionrc motor plate: 15
Penguin chassis: 75
GH Aluminum knuckles: 16
GH Aluminum steering slider: 15
GH Aluminum universals: 13
GH Aluminum upper bulkhead: 12
GH Aluminum front body posts: 6
GH Aluminum rear body posts: 6
GH aluminum ball diff II: 25
Hpi rear tires (carpet): 7
Hpi front tires (medium): 7
TRC front tires (hard): 10
TRC rear tires (soft): 10
Large front bumper: 5
150mm belt: 9
Hpi rear ball diff: 26
Ball diff mant set: 3
13 tooth pinion: 4
Orion stock motor: 10
Aluminum front shocks: 15
Vcs shock: 15
Orion battery pack: 30
Radio system: 50
Extra reciever: 30
Extra crystal set: 15
Soldering iron, and misc.: 28
Misc pinions: 14
Alfa body: 15
Silvia body: 15
Carbon fiber sticker: 5
Epic binary2 motor: 60
Duratrax digital charger: 50
Custom 8-cell battery pack: 35
Long white body pins x4: 8
Body paint: 16
Venom speed meter: 50
GM V12 esc: 160
Shock oil: 10
Hitec servo: 25
Ball bearings: 15
Ball ends: 5
Total: 1068
ajg is offline
Old 08-17-2004, 09:55 PM
  #520
ajg
Registered User
ajg's Avatar
2/3SC
Yeah, I forgot about that. Well the 42g cells was 7.2 volts.
ajg is offline
Old 08-17-2004, 09:58 PM
  #521
schulze makes escs for brushed motors that can handle up to 12 cells.
You can also use airplane ESCs.
Or you can always go to the good old on and off switch activated via servo. (you would definately need a failsafe because it is higly likely that your car will go out of range and the switch will be stuck on
Old 08-17-2004, 09:59 PM
  #522
ajg
Registered User
ajg's Avatar
If I go with more cells will I have to get neodynium magnets for the motor?
ajg is offline
Old 08-17-2004, 10:47 PM
  #523
Where are you getting this from?
neo mags will up the motor performance but it is not needed for high cell count.
Also, i don't think anyone even makes some for quad mag motors.
Old 08-17-2004, 11:34 PM
  #524
Nevertheless, if you want to get to 80, 80+ with your micro, sell the rest of your r/c equipment! It is gonna cost you, big time! And after you got it to go 80, the motor gonna be wasted, the thrill will be gone, and if you ever try to put it on a track, you are going to get dusted, because you gonna find yourself all over the track with the speed it'll have. Then again, in a 5 to 10 min heat, you pack may dump before its over.
Lithium Poly cells cost money! It is like new technology for me. I just found out about a month ago that they even made NiMH AA cells, and I have 13 Lithium Poly cells (non rechargeable) in my hobby room (really a junk room, according to my wife). Don't ask where I got those from, but they were free. At 3.6 volts a cell, I am scared to use them in anything!
Old 08-18-2004, 06:01 AM
  #525
ajg
Registered User
ajg's Avatar
http://www.neomags.com/magnets.html
ajg is offline
