What should I expect from buying a Peak Vantage Touring - Surikarn Edition 10x1 motor
#31
Timing refers to the alignment of the brushes with respect to the magnets in the motor can. As you advance the timing, you are essentially shifting where the electromagnets created by the armature "push" in relationship to the static magnets of the can. As a result, you increase the top end of the motor, and reduce torque. However, the motor tends to heat up more and become less efficient. I agree with fatdoggy that the better choice for club racing tends to be lower timing and gearing taller. Jedi, note: I said tends to be better . Jedi seems to be the nitpicky type. Advancing the timing of the motor will tend to increase power, since the additional gained rpm exceeds the torque lost. But, if you advance the timing too far then both torque and rpm will be lost, resulting in less power. So, let's say you advance the timing from 12 to 18 degrees. You'll have more rpm but need to gear slightly shorter to make up for the lost torque. All in all, you should theoretically have a faster car in top-end. So, why don't we all run 40-50 degrees of timing, right? After all, we can gear down....
1) Inefficiency. The motor doesn't convert current to mechanical power as effectively, which means more battery power is turning to heat.
2) Motor fade. As the motor heats up, the magnets will further weaken, making the motor even more inefficient and "soft".
3) Torque issues. Even if the motor is cool, advancing the timing beyond a certain point will really start dragging down the low-end of the motor such that you can't compensate with gearing. So, you could have a car that is a rocket, but ends up taking several hundred feet to accelerate
So, 12-18 degrees of timing tends to be a good range. I don't think it is worth spending a lot of time messing around with it. All else equal, you could consider lowering the timing a little if the track is really hot. Otherwise, the factory timing is correct 99 percent of the time.
#32
So the "timing" really is the angle between the electro magnets and the static can magnets? And it sortof decides "when" the push against the static magnet will be made?
#33
basically, yes.
#34
Just something else to think about.
More timing = More off power drag. More deceleration.
Less timing = Less off power drag. Less deceleration.
#35
Surikarn 10x1
This motor rocks. Geared 8.44(18 degrees timing) on a medium sized not real tight track in an IRS TC3 makes the car fly! Excellent toque out of the corners, great speed on the straights and excellent run time.
Highly recommended.
Highly recommended.
#36
Originally posted by rcnewb2004
mw: a diode will do what I have mentioned, however, why does it have to be a schottky diode, i heard it has a "high forward voltage" or something.... what advantage does the "schottky" diode have compared to just a plain old diode?
i bought the motor. i am so eager to see it.
I'll admit that I don't know exactly what the answer is to this one, but I'll give it my best educated guess. If anyone knows a better answer feel free to chime in.
A schottky diode is basically a one-way filter for electric current. It allows current to flow in one direction, but not the other. When you apply braking to your esc, it actually causes the motor to slow down rapidly by shorting it. Over time, this short is what caused the brake fets in older speedos to burn out. Because the schottky only allows current to flow in one direction, it "buffers" this short, so to speak. The "high forward voltage" you heard someone mention is probably just their way of saying that the diode only allows current to pass when you apply forward throttle (forward "voltage") to the motor. It won't allow anything else. You can quickly destroy a schottky if you ever install one on a motor connected to a reversable speedo. As soon as you apply reverse throttle, it will be toast.
As far as how a schottky compares to other diodes, I honestly have no idea. Schottky's are the only diodes I've ever used for anything, so I've really got no point of reference to go off of. Anyone know?
#37
mw: cool I think you helped me figure it out now. The specialty of the schottky diode is that it has a low forward voltage. That probably means the voltage required to activate the "oneway" effect of the schottky diode is lower than of a normal diode. However, I could still be wrong because this is still my guess. So ppl out there, please correct me if i am wrong!
and not too long ago, i did ask the question "is there a difference between a red and a black wire"? hahah and well u know what happened to me hahah... i got schooled.
Tanman:
Thanks man... I ordered the motor. I am just getting too much positive feedback on this motor. I think I will gear it to 8.0-8.5 depending on my track and adjust the timing accordingly. Thanks for all the great advice guys!
Fatdoggy:
I am sorry, I am not too sure I understand your "power drag" concept... can u explain it further?
Just think of me as not just a newb, but a retard at the same time.
Tanman:
Fatdoggy:
#38
Originally posted by Big Jim
Hi FD,
I'm wondering why anybody posts anything about motors on that site when people have to come here for the answers anyway. If someone does post any worthwhile info there, in 3-4 days you'll never find it again.
I never really thought about it before because you can always dial in or out as much drag brake as you need anyway from the TX on a good radio regardless of how much timing is on the motor.
But makes sense though. As we all know, drag brakes is a function of the TX setting that controls that part of the ESC circuitry but it's really just "partial dynamic braking".
Under a dynamic braking situation, the motor becomes a generator putting out power instead of taking it in. This is where the term "regeneration" comes from. In theory, under braking when the motor is generating power, it sends it back into the batteries, thus adding a bit of runtime.
Electrical timing on our motors in any amount and on either side of the "0" point is a three-way relationship between the brushes, armature coils (and segments) and the magnets. Running a lot of advanced timing on a motor causes it to draw more current under heavy loads. It does this because it takes power to make power. If you want more punch you advance the timing so the motor draws the amps it needs to make the power to push your car harder out of the corner.
With the timing set the same and under a braking situation, the motor puts out a lot of amps the same way as it was using coming out of the last corner. Anytime a generator is putting out a lot of current, there's a bigger load on the drive source. The drive source of this generator in your car during dynamic breaking is the car's momentum. More drag on the car's momentum and you slow down quicker.
This is usually cured with just a click or two on the TX brake adjustment.
Hi FD,
#39
cool thx alot FD.
Btw, anyone know the cheapest place online to buy enduro brushes? my lhs is charing $5.50 for a set of sprint brushes.
I need somewhere that's going to get me some better prices!
#40
$5.50 US? You're getting ripped off. Try any on-line shop, like Stormer or Tower. I don't think they have any bulk packs yet.
#41
yea $5.50 is WAY too much.
I will check around for some brush packs.
Are the springs that come with this motor ok?
#42
Is there any store online that is selling bulk packs of enduro brushes for the v2 motor?
