LOSI EIGHT W.0 RTR BUGGY W/EXTRAS
LOSI EIGHT 2.0 RTR BUGGY W/EXTRAS
The following items are for sale as a pkg. deal
1. Losi Eight 2.0 RTR Roller - chassis in Great Condition, used as back up racer. Raced Only!! Body is in fair condition.
2. O.S,. VZ-B V-Spec .21, fully modified by RB Modds (crank, crank case and piston/sleeve/rod) ceramic rear bearing & heavy duty steel front bearing also installed by RB Modds (1 gal on motor) Also comes with extra piston/sleeve/rod modified by RB Modds fresh & ready to drop in.
3. Airtronics 94361Z Steering Servo 5 races only, like new! (aluminum heat sink)
4. Airtronics 94362Z Throttle Servo - 5 races only, like new! (aluminum heat sink)
5. Losi flywheel . . 13 tooth clutch bell set is on the motor.
6. Losi flywheel . . new
7. Losi air filter set-up . . used but in great condition
8. Losi 1400 MAH rechargeable 5 cell hump pak battery
9. JP-2 Pipe . . used but in good condition
10. Axial wheel wrench . . excellent condition
11. OFNA True-Start Starter Box. . setup to use with Losi Eight 2.0 RTR Buggy. .comes with (2) 12 volt batteries and a (1)12 volt charger . . used but in good condition.
12. Losi 1 piece quick change motor mount . . used but in great condition
13. Thundertiger ignitor and charger . . used but works very well
14. Panther, Losi and GRP tires included.. more description upon request.
Asking $750/obo
Asking $750/obo
