Hot Bodies D8 Tips/Set-up's
#31
I know this is the D8 thread but has anyone tried this setup on a VE8? I would think it would cross over pretty well since the front and rear sections are identical....Also, this setup i would imagine is with the stock plastic 1 degree rear hubs ( 3 inboard and 1 outboard)?
#34
Brake bias is a personal thing. Never heard of running more front brake. Problem I see is that if the front locks under braking, you lose steering. More rear brake gives the ability to swing the tail around.
#35
#36
thanks for the response. correct if im wrong but thinking where the nitro motor is, the battery is in the same location and similar wieght. Where the fuel tank is (full of fuel) would weight similar to a brushless motor (may be a bit heavier). And on the other side of the car the servo is in the same spot and radio box. The receiver pack is in the same spot as the ESC. Sounds like it should be pretty close. I will agree that the overall weight of the VE8 maybe heavier with the thick plastic chassis. May just have to go up in oil wieght a little.. I will try it out this weekend.
#37
#38
Very intrestead, please post or PM me what you think.
#39
I struggled alot with the D8 for quite sometime. I spoke with Josh Alton and came up with small areas to work with that were overlooked by many.
Front
Shocks- Outer hole on tower, outer hole on arm.
Camber link- Lower hole on tower, inner hole on hub.
Shock oil- 400 with 1.4 pistons.
Shock spring- Gray 60mm with long truggy ends. Cut off 3mm on the long truggy shock end. Total length 103mm.
Diff oil- Remove the shims from the internal gears. Diffs are too tight. 5K oil.
Rear
Camber link- inner bottom hole on tower, inner hole on hub.
Hub Position- upper hole if traction is present. Lower hole if traction is needed, hubs in forward position.
Diff oil- Remove shims from the internal gears. 3k oil.
Long shocks, Yellow 68mm spring. 110 length. 350 oil, 1.2 piston.
Center diff - 7k
Ride height- 28mm front, 29mm rear
Camber- -2 front and rear.
Sway Bar- 2.4 front, 2.8 rear. If more rear traction is needed, go to 2.5 rear bar. Mugen or Odonnell bar fits fine.
This setup is the easiest to drive that I have found. Car works well.
Front
Rear
Center diff - 7k
#40
ooops, double post
#41
Hi guys, I've been reading this thread intently as I have a D8 coming
I guess all these setups are for your dirt tracks over there.... does anyone have a good setup for grass? I guess it would be about as bumpy as an average to rough dirt track over there.
PS: - I haven't seen a D8 yet but why are we gluing the diff cases down to the chassis with silicone? Aren't they sealed like all others?
#42
If your car is not responding well, then just the setup on page one of the thread. It works great on dirt but I have no idea how it will handle on grass. Your best bet is to buy a lawn mower for the grass
#43
Putting sealant on the diff cases is optional. I don't use that method and I haven't had any problems with dirt getting in the cases.
#44
Thanks RCelik
I seem to recall from grass racing many years ago it was stiffer springs, lower ride height, stiffer swaybars to minimise traction rolls and virtually no droop.
But that was a long time ago so looking to confirm my fuzzy recollection and also to get some numbers / hole positions specifically for the D8
#45
Thanks RCelik
