Capricorn LAB C801 1/8 scale
#886
#887
#888
[QUOTE=dj apolaro;12434513]Without using numbers I will explain how the links work and you can see what position you want to use.
Just know this, the longer link give more stable feel with less reactive response.
The more angle the link has, the more off power stable and more mid corner and exit rotation
The flatter the link, the more off power steering (slide) and more traction once you get on power.
Hope this helps
DJ Apolaro[/QUOTE
Dj, one question about the angle.it is the same if it is angled from the hub or the camber plate??
Hope this helps
DJ Apolaro[/QUOTE
#889
Has anyone tried the LAB C801 CE? Is that good?
#890
[QUOTE=GREGORY!;12470867]
Sorry I took so long. I was out of town at a race. It is different on the hub versus the inner pin. The further in the pin is, the more roll the car should have and also be more stable since the arm is longer.
DJ
Hope this helps
DJ Apolaro[/QUOTE
Hope this helps
DJ Apolaro[/QUOTE
DJ
#891
This weekend we finally had the shakedown of our 1/8 electric car.
I think the amount of power is 90% there, just need a little more topspeed.
Now we can focus on improving the handling, you can see in the video it's nose heavy which causes a lot of understeer.
A new design to cure this has already been made and hopefully we can test this within two weeks.
The car is based on a Capricorn C801.
http://www.youtube.com/watch?v=7dwDdRAz1gk
+ YouTube Video | |
#892
NICE
6S ????
6S ????
#893
NICE
6S ???
6S ???
#894
Hello,
Can someone help me with good set up for law traction track? I need to have more steering .
THANK YOU .
THANK YOU .
#896
Have some pictures?
Have some pictures?
#897
Nope, since this is the first electric 1/8 which can beat a nitro version I'm not planning to post any pictures.
I did post some renders of the mule I designed to develop the drivetrain and power package. That's basically the car you see being tested in the video.
The actual car will be a ground up 1/8 ep design.
#898
okay,
Characteristic of me;-)
But do not let us wait too long;-)
#900
+ YouTube Video | |
Maybe you could put a tape recorder on it for the car like sounds?!
BM
