Capricorn LAB C801 1/8 scale
#751
Hello ,
I just bought a new capricorn ,but before i was driving mugen MRX5 for 2 years and i know everything about Mugen , but about capricorn i don't know too much .
What is the distance for body Protoform prf18 ?
What is the parts that braking faster then other and what about belts.
What is the best solution to hide all cables from servos ? Is there any radiobox that possible to adapt for this car ?
Thank you!
Thank you!
Congrats with the car, hope you will enjoy it as much as I do
I mount my PRF18 app. 13-15mm distance from the front bumper, for me this works fine, if I increase the distance I do not like the steering feel. But this is my personal experience.
What I general use/change are the pulley´s, belts and bearings (the small two 3x6x2.5 flanged bearings) in the belt tensioner. These items are checked and exchanged when wear are found.
What I have broken when crashing with the car , are basically the front bumper (cap-2080) and front body mount (cap-2079)..
What I can recommend to buy from the option parts are the new flex chassis (cap-2090b), for me this made the car handle much better. I got extra steering in and out of the corner, and in my opinion the car just handled better. I sell it for 94USD and give additional discount so it ends on app. 81USD....
Hope this has helped you a little.... Thanks
#752
Hi,
Are you talking about radio plate (CAP-2090b) or the WC chassis (CAP-2114WC)???
#753
Has anyone else noticed that the wheel axles seem to have a slightly looser fit with certain brands of wheels/tires compared to other brands of car?
On my old Mugen, all the wheels I used had a very tight fit on the axles, with the Capricorn most wheels I have tried are quite loose and can move around a little when fully seated.
#754
#755
#756
Thanks, I actually just got the revised hooks and they are much better. But the problem I was describing earlier was not side to side movement, but rather up and down as if the axle itself is slightly smaller in diameter.
For instance it is much easier to slide wheels on and off as opposed to my old mugen which had a very tight fit.
#757
reply
interesting information
#758
I got a couple of emails for my 1/8 set-up from this past weekend at the Homestead State Race. My car was pretty good and very consistent to drive. I was able to set the TQ (with the only 25 lap run), set the fastest lap of the weekend with a 16.7 and was leading the Final until I had 2nd gear strip. I had hit a wall earlier and think my motor moved. My car was the fastest and drove really good. I used the newer Protoform R18. It was smooth to drive. The 909 had a little better steering, but not as consistent.
If I did not put something or missed something on the set-up just ask and I will try to get the info.
Thanks,
DJ Apolaro
Thanks,
DJ Apolaro
#759
#760
Hi
For the C801 does anybody have the P/N's? of the
rear arms upper stay Carbon version with the square roll centre inserts
and the P/N's? of the square roll centre inserts themself.
I coudn't find them on the capricornrc site. Found only the 2095c with the long holes.
#761
#762
Hi
#763
Yep, for the square ones you need to order 2095Q, they come with one set of the square inserts included... You can purchase them from me; [email protected], just send me an email if you want them..
#764
#765
C801 Lamberto Collari Edition
Remember to order your C801 Lamberto Collari Edition :-)...
Parts changed or updated:
Additional weights under the tank (35-18b and 37-18mix)
- All the Suspension parts in hard Plastic (original part number + a B in the end)
- Radio plate (2090b)
- F1 sway bar (2160)
- New carbon parts Front/Rear Shock Towers (2092b+2089b)
- Rear damper plate new (2094s)
- New belts (cap2009rb+cap2010rb+cap2011rb)
Send us an email for prices, we also have a upgrade kit available.
sales(at)rc-netshop.dk
