Team Corally RDX Touring Car
#9181
Originally Posted by rayhuang
To add to Jimbo-wide hexes are standard when running Jacos. YOu should always run the RDX 190mm with foams is my experience so shim the arm mounts out as much as it takes to hit 190mm. The cars more stable and carries more corner speed the wider you make it. a 4 to 5' circle is all you should need. If your running smaller than that-then you might want to think about some set-up changes to gain steering back.
What's the difference if I shim under the pin holder rather than out at the hex?
#9182
Originally Posted by King of B Main
Great job Ertracter, and Toni . Way to represent. Toni are you sponsored now by corally or still by efactor
Thanks, my sig will letcha know... BTW I'm a big hairy dude so I spell my name with a Y See ya on Sunday
#9183
Originally Posted by Jeff Brown
It has not been put into the system yet. They arrived as we left for Vegas.
You also need 38mm turnbuckles. The part number is 79273. The retail on the topdeck is $35.00.
Jeff
Jeff
#9184
mine measured to be 3.8 mm thick.
#9188
Just my quick 2 cents...I switched to a T2 from a well set up RDX. BIG MISTAKE!!!! I missed the hell out of my RDX the last 3 races and am looking to pick up another one. I'm sure the T2 has it's good qualities but I can't get the damn thing to turn and rotate nearly as well as my RDX did. I WANT MY RDX BACK!!!!! This is one of those defining moments where you realize you did something VERY stupid.....
#9189
#9190
Originally Posted by Apex
I notice when using Jaco Foam Tires the front tire rubs the shock which also limits the amount of steering travel. What have you done to fix this? I'm thinking about just adding spacers to space the wheel out more until the track is 190mm. Any ideas, suggestions???
#9191
Just a quick kit question......If it is one of the kits with the chassis pre drilled for the motor guard (US Carpet Spec Kit), is the chassis also already set to accept the Specialized offset motor mount?
#9192
Originally Posted by dodgeguy
What set up are you running on the T2? It may not be the car but your set up. But I my self have a T2 now and am looking to trade for an RDX to try for carpet. It does seem,by looking at the RDX on the track, that it does rotate very easy. I think sometimes some drivers have better luck with certain cars.
#9193
I spent a ton of time with different setups and trying different things. Last thing I'm going to try is a more conventional shock oil setup and tune with oils. Very well built car but just not my RDX.
So I have an RDX now on the way to try.
#9195
Well_I am going to try my hand at Rubber tires again. Talking in large generalities that the fastest rubber tire/carpet set-up is one in which you can spin the car out at will, but when driven smoothly with throttle inputs going to the apex that you dont spin out?
In other words-if you are to dial a set-up in thats flat planted and can even be driven aggresively and rear remains planted that that set-up is inherently slow? I think I am going to start with Ertracters (sp?) IIC set-up.
I need to know these things since I have NO ONE to practice against on rubber tires till the Halloween Classic practice starts. IN the meantime I'll try around 1 to 2 seconds off the foam tire stock laptimes-depending on whos setting the laptimes (ie. Goetz or Hermmann).
