Team Corally RDX Touring Car
#9151
Originally Posted by ERTRACHTER
congrats to all the corally crew that made amains at the iic in vegas
BTW - You're going down this weekend sucka (we're not at a big race so I can start talking smack again )
#9152
I was one of the lucky guys to make it out to the IIC this year. Unfortunatley, I had mostly unlucky results. but, more importantly I gained a ton of knowledge at the event!
the reason i'm writing this is because I would like to pay some thanks.
First, Thank you to Jason Ertrachter and Jeff Brown for always helping me out with setup tips.
I would also like to say thanks especially to Corally's Aaron Young. He really went out of his way to make sure me and my freinds corally's were working good at the race. This guy is truly a class act!
#9153
New Top Deck
I picked up one of the new top decks at the IIC and need some information about it from someone who has actually used one. No speculation pleeze...
Considering its thickness, I assume that the new deck is only applicable for carpet racing. True/False?
With the center steering, some people are telling me MORE steering while others are saying LESS. Which is it?
Many thanks.
Many thanks.
#9154
#9155
Originally Posted by rc_bam226
If you bought it new, you have to lube it. The manual suggests that you use the diff lube, but alot of fellow users here prefer Associated black grease to lube the thrust bearing.
#9156
Many thanks.
Many thanks.
A 2.4mm for asphalt (rubber) and a 3.4mm for carpet (foam).
I hope it gains more steering, because my car is understeering most of the time.
#9157
Originally Posted by TWISTED
Hi guys just got my next top brace and was wondering if anyone had trouble with the front belt rubbing on the screw on the bottom of the bell crank ? I put mine on and it seems to be rubbing is this a problem or have I put it on wrong?? Thanks
#9158
Many thanks.
Many thanks.
Overall it just felt like the car wanted to keep turning around the apex whereas previously it would wash out and understeer across the apex until extra speed was scrubbed off.
#9159
Guest
Originally Posted by Cookie
I used the old bell crank posts that have a slightly shorter base and hence make the bell crank sit higher in the new center point configuration.
#9160
Thanks Cookie I did what said and works like a charm thanks mate.
Actually I also found the two ball studs now on the one bell crank caused the ball cups to rub against each other, not a major issue but does bind a little. I Just sanded the offending areas a bit so they don't rub too much, just slightly.
Anyone know if there's going to be a new bell crank as well?
#9161
I raced with the new top deck and center point steering last Saturday and found that it increased the mid corner steering and car rotation quite significantly. I found it required less steering input for same amount of turning which then also provides the increased steering when required.
I have that understeering problem, tried many things, but this seems to be a solution.
#9162
Originally Posted by Big Rigg
Congrats yourself! 6 seconds ahead in stock qualifying, talk about domination! You were on an awesome run in the 19 main too I swear that flapper jumped out from right behind me Thanks again for all your help!!!
#9164
ill see you there juan and yes it is on
#9165
Great job Ertracter, and Toni . Way to represent. Toni are you sponsored now by corally or still by efactor
