Team Corally RDX Touring Car
#9136
Thanks Robfo, do anyone else have a set up for wet race. thanks.
#9137
Originally Posted by syndr0me
Ollie, how come you're not in Vegas?
Greetings Ollie
#9138
Originally Posted by RichO
I have a strange issue that raises two questions.
After getting the car built, I noticed that something had changed once all of the chassis and bumper bits were screwed on. The front diff has a nasty wobble in it. I have rebuilt it a few times (and it has never been run). The wobble is bad enough that the belt chatters since the teeth are catching the side.
The docs are a little sparse when it comes to the front diff (unless I complete missing something):
1. Is the long half supposed to be on the left or right side?
2. Has anyone else had a problem with a wobble - if so, did you manage to fix it and how?
-Rich
-Rich
Goodluck!
greetings Ollie
#9139
jeff brown you have pm!!1
thanks!
thanks!
#9140
Originally Posted by Nuno Gancho
Hello, i would like your help for a set up for a wet race, i will use pit shumizu tires. What set up should i use for the rdx, i have the chassi 2,4cm normal, 2,4cm world champion collegno, and 3cm normal, and upper deck? And about the insert, and wheel. Thanks very much.
Greetings Ollie
#9141
Originally Posted by shaggster
Have you tried it out yet?
#9142
congrats to all the corally crew that made amains at the iic in vegas
#9143
T1/Ollie : Thanks for the information. I will take a look at both of those things tonight.
#9144
I need some help finding the washers that go with the screws for the hinge pin blocks... my manual shows part no. 1235 and that doesn't seem to be a good number at Corallyusa or stormers... I need to pick up some spares since I lost one after not using loctite to secure that screw... I also need to be able to mail order since there is no local support for the car. Thanks
#9145
http://www2.towerhobbies.com/cgi-bin...?&I=LXDSD4&P=7
You can use these type washers. Thats what I did and I have had no problmes. I technically used the crc purple ones, but that was just to match another color on my car. You can also add them above the steering posts for some color. I also used matching nylon lock nuts to attach the shocks to the tower. Bling it on my friend.
#9147
Guest
Originally Posted by TeamPink91
I just got mine today, and I live in the US. Yea it's pretty much a bolt on. All you have to do is use the left side bell crank and relocate one of the ball studs so they are both side by side, and then flip the bell crank post upside down so it screws into the topdeck rather than the chassis.
#9148
Originally Posted by OllieRDX
The prob with the wobble is that your trust bearing is broken or isn't completely straight in the outdrive! thats the most important thign about an RDX diff!
Goodluck!
greetings Ollie
Goodluck!
greetings Ollie
#9149
Originally Posted by 8800
looking down at the diff screw on a built diff it looks like the screw doesnt stay central in the diff half. They move up and around as you rotate the diff, I'd of expected it to stay bang in the centre, is this what happens or is there something wrong
You're trust bearing is broken or its not straight in the outdrive!
Greetings Ollie
#9150
