Team Corally RDX Touring Car >
Old 07-09-2006, 02:44 PM
  #8041
HarshGuy's Avatar
Originally Posted by syndr0me
Harsh,
Is there anything at all that's binding up your front axle? Are you tapping boards or anything when the belt slips? Seems like with a solid front axle, any stoppage of the drive train, even momentarily can make the belt jump.
Nothing is bnding up at all, and yea it defeinitely happens when I hit things, or tap the wall (or back markers pursuant to the "3 turn rule" LOL), not necesarilly hard hits though ....others dirving corallys hit harder with no issues ...wierdest thing????
HarshGuy is offline
Old 07-09-2006, 05:16 PM
  #8042
Trader Rating: 40 (100%+)
harsh,
I would definately replace your belt. After it flips over once it is always going to happen. I had the same problem until I replaced my belt and made sure my tensioner was lined up center with the belt. You need to replace the belt for sure.
King of B Main is offline
Old 07-09-2006, 05:20 PM
  #8043
oh yah make sure your pinion gear to the moter is not touching the belt, and also you said it happens when you hit something maybe its your battery hitting the belt.
Old 07-09-2006, 06:03 PM
  #8044
EricO3's Avatar
Originally Posted by King of B Main
harsh,
He mentioned he already tried a new belt.
EricO3 is offline
Old 07-09-2006, 06:39 PM
  #8045
well after it flips once he needs to replace it
Old 07-09-2006, 06:47 PM
  #8046
kartermdb's Avatar
Trader Rating: 15 (100%+)
my belt flipped once, and hasnt flipped sense, but i did make sure to clean the pulley good, stuff builds up in there, just take a small pick, or .050 wrench and take your time
kartermdb is offline
Old 07-09-2006, 07:08 PM
  #8047
HarshGuy's Avatar
Hummm ...good suggestions, one thing, I have been using these EA packs and they came with battery bars that are "taller" than the SMC ones I normally used, that may be the ticket (look at the last pic I posted), the battery ars are "right at" the belt!
HarshGuy is offline
Old 07-09-2006, 07:11 PM
  #8048
HarshGuy's Avatar
Yea after the 1st time it poped off I put a new belt in it and it also poped off.
HarshGuy is offline
Old 07-09-2006, 07:14 PM
  #8049
Team EAM
Trader Rating: 79 (100%+)
Hey Harsh,
Try moving your belt tensioner back to the hole in the middle of the deck instead of right at the front pulley. I had that problem when I ran a corally and when I moved the tensioner back it never happened again. I think Jeff Brown and a few of the other "Factory" Guys run there's back there....if they run one at all.
EA
EAMotorsports is offline
Old 07-09-2006, 07:18 PM
  #8050
HarshGuy's Avatar
HarshGuy is offline
  #8051
HarshGuy's Avatar
Originally Posted by EAMotorsports
Hey Harsh,
EA
OK I'll try that as well ...no issues with the bars you normally send then? (those packs ROCK btw, even after beeing "tortured" at 10 amps at the nats ).
HarshGuy is offline
Old 07-09-2006, 07:20 PM
  #8052
Team EAM
No I never had any issues with those bars. Those are the same bars that TJ Bradley, Jeff Dayger and all the other SMC Drivers use now....THey are made by intellect.
EA
Old 07-09-2006, 08:31 PM
  #8053
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Anyone in here running or want to run the orion/kokam lipo batteries in their corally? I am working on adapting the Orions to my corally in a "factory" looking manner. Just looking for ideas. After weighing the lipo and a 3800 6 cell I seems I will have to add about 136 grams to the battery side with a brushed motor. Just looking to share information and ideas. thx.
andrewdoherty is offline
Old 07-09-2006, 09:23 PM
  #8054
HARSH- had the same thing happen that night in mod found out that my spool screws were backing out. I put lock tight on them now and I am going to moving the belt tensioner back to the middle hole to see if that helps.
bigdog is offline
Old 07-09-2006, 10:17 PM
  #8055
syndr0me's Avatar
Trader Rating: 32 (100%+)
Let me know how your experiment goes with the LiPo, I'd like to hear about it.
syndr0me is offline
