Team Corally RDX Touring Car
#6391
6 degree
#6392
Question, is it just my car and the set up on it that would make the front tires wear ALOT faster than the rear. any help would be great. thanks in advance
#6393
It has to do with the setup and your driving style. If you have a setup that natually has a push to it, it'll wear the front tires more. Also, if you're driving hard into the corner instead of smoothly, that'll also wear them more. Combine the two, well, then you get a lot of wear.
#6394
thanks. the car does push alot , is there anything i can do besides the basics to stop it ( camber 2 deg , springs 26 lbs, caster 4 deg , 60wt oil ) on carpet. thanks again.
#6395
Suspended
Originally Posted by Obsidian
Hello Everyone,
Just wondering what caster blocks are prefered when racing on asphalt (2,3,4 or 6deg).
well it depends on the layout...i have been running 2 for over a year now...i mostly run on asphalt ...works great on power steering . going to 6 will make the car very difficult to drive off power not consistant for the most part..
#6396
Hello Everyone,
#6399
Originally Posted by Brian McGreevy
Joerocket,
Check out mine or Jeff Dayger's setups from the Novak race on the Corally USA website. They'll point you in the right direction.
Joe,
I am using McGreevy/Dayger combo setup on mine and i am 90% there on setup - i am driving on a medium bite ozite technical track.
marc
#6400
RDX PICS
DUE TO POPULAR DEMAND, HERE ARE THE PICS OF MY RDX.
PLEASE REFRAIN FROM PM'ING ME IF YOU ARE NOT SERIOUS.
#6401
mcgreevy, i have almost your exact set up on my car , as far as springs , wt oil , camber link positions, camber , droop. the thing that i dont understand is that there are a few other rdx's at my local track and they dont have this problem, and you could almost say its the way i drive , but i didnt have this problem with my xray or tc3'S. im going racing tomorrow and i changed a few things so i will see what happens. one more questions, could bump steer make your car push? thanks for all your help.
#6403
i just picked up a 4mm chassis....will i need to do anything to the dayger setup if the bite is not quite up, for practice during the week when the traction drops off??
Soften the front end?
#6404
Well, Brit and I converted another one today...that makes 3 regulars now with a RDX.....
#6405
off of your novak 06 set up , i dont have the low roll blocks, im running 1mm shims instead of 2.5mm shims, softer front springs 26lbs and thats it . are you running kickup? have you ever ran anti dive in the front?. thanks
