Team Corally RDX Touring Car
#5956
Originally Posted by Brian McGreevy
I see...Jeff wants less camber regression.....and he wants turn-in. Spool? Methinks yes.
Back to HW for me now...lol
But i want to develop a one-way setup this year.
Jeff
#5957
Originally Posted by Jeff Brown
I have 0 deg caster blocks on my asphalt car at the moment.........
Jeff
Jeff
#5958
Welcome Mr. McGoo. Is Mrs. McGoo going to join the fold as well?
If I knew you were looking for a new ride I would have let you taken my RDX for a drive when I was up there on the 19th.
I'm kind of in the same situation as Team McGoo by dusting off the RDX after a year to run the TSC in March. I'm set up basically stock with the short camber links, 4 degree caster, and not using the low blocks. Let me know what you think is a good spring weight start point after you run it Sunday.
If Ron & Wes could throw me some hints for this track, it would be very appreciated too.
Thanks - See you in Dallas next month.
Oh, and thank Andrew again for me for loaning me his Fantom motor. It wasn't over geared; I didn't have my radio endpoints and speedo configured right. Can't think of everything after a year hiatus.
#5959
Originally Posted by FBJ's RDX
Hi Jeff, is it ok if you post your current spool setup with the 0 Deg Hubs? Thank you
Jeff
#5961
Originally Posted by Sushi Boy
Post my carpet setup while you're at it as well lol.
#5963
Nice!
Ok, mine is done and uploaded. I will work on Korey's now.
Jeff
Jeff
#5964
Hey Jeff, 0 degree caster blocks on your car? wouldn't that make the car seem a little darty? I run 6 on my asphalt car, with a spool and 1 degree rear toe in on the rear. I'm thinking of trying a sway bar in the front to see if I can get the front to stop sliding because of the spool, as I believe the front inside tire is lifting up too much. I have about 1 mm of droop in the front and 2 in the rear. I also have no couplers in the front (very narrow front). Let me know what you think about the sway bar. Thanks,
Kenny
Kenny
#5965
#5966
Jeff
Pay me.
Jeff.....bud you never tell me to pay ya!!.....
#5967
i won't be able to run this sunday....have Mavs tickets, but i should be practicing sometime this week so i will let you know, wes and ron have helped me out quite a bit, so i have a pretty good starting point i think....
marc
#5969
Mr Magoo...let me know when you are going to run it, i am very interested....currently cant run the t2 due to no shock towers.....
