Team Corally RDX Touring Car
#5851
http://international.corally.com/PDF...%20English.pdf
This is the Assassin manual, go to page 7 and it shows how it fits together.
Cheers
Peter
Cheers
Peter
#5852
Thanks for that, it's all sorted now.
Wills
Wills
#5853
Originally Posted by Dusty Kemp
Thanks Pace! I noticed before we left that you weren't entered this year. Are you still racing in circles? I thought I saw your traveling partner(older gentleman) but didn't get a chance to talk. I've been purposely waiting until after the 'Birds to build the RDX....and as badly as I did last week I shouldn't have waited! I'll be in touch with you soon on advice for an oval guy wanting to do on-road as well. You are right though...thie site and these guys give great advice and setups.
Bon chance!
dk
Bon chance!
dk
yes i m still running oval...but in my area it s only 4cells stock and i m not a big fan of 4cells stock anymore!
the best think i can say to an oval guy who want to run on-road is "PRATICE"!!
good luck!
Pace
#5854
A little late, but I have a question on the ball sutds for the steering. If you take the rear ball studs from the shock tower, into all the steering components it gives you 0 degree of bump steer? Where in the steering do you put them, and how does it give it less or none bump steer?
#5855
If you put them where the front toe link mounts to the steering bellcranks it will move the inside of the toe link further down. This prevents the wheels becoming more toe'd out as the suspension is compressed. This will result in slightly smoother entry, and more mid-exit steering.
-Korey
-Korey
#5857
CorallyUSA
Can you post the setup from the Team Driver at the Snowbirds 2006 please!!
Tossolini,Dayger,Cuffs,Simo and the rest of the team!!
Thanks A Lot
Thanks A Lot
#5858
Originally Posted by Mr. Shookie
Sweet post it when you get r done...the paint isn't the prettiest but it worked...LOL
-Shookie <><
-Shookie <><
http://www.gearchart.com/index.cfm?f...tsblank&type=1
it's the one titled "Editable Corally RDX Blank Setup Sheet"
LMK what ya'll think.
#5859
Originally Posted by HarshGuy
OK I got an editable setup sheet up ...go here:
-Shookie <><
#5860
NICE>>>>>> just have to get on the other computer so I can print it...LOL
-Shookie <><
-Shookie <><
#5861
I just noticed on the downstairs computer (did this on my sub notebook upstairs while wathing olympics ) ...the weight numbers and dots are really tiny, when you print they're viewable but could be a tad bigger as well. I'll get another version out tonight or tomorrow ...I've got to head to the track this morning and kick some Xray/Schumacher arse.
#5862
clarification on bumpsteer modification
To clarify, do you want to add the spacers (~4mm) to lower the ballstud on the steering block (out toward the wheels) or the bellcranks (mechanism over the drive belts)? What does this allow the car to do again and why?
Thanks!
Thanks!
#5863
Corally USA,
When will all the new option parts for the RDX (motor guard/fan mount) be available? Also does anyone know anything about the new 12X, how much and when available? Was this what the team was running at the Snowbirds?
#5864
The motor guard/fan mount is available right now. So are the narrow rear hub carriers, and the 3 deg caster blocks as far as I know. The New suspension arms will be here soon. I'm not sure about the sp12X though. Hopefully soon because I cant wait to start running one.
-Korey
-Korey
#5865
so i can put the 4mm ball studs on the steering BELLCRANK, or the ball cup[s that connect to the hub carrieers to the bellcrank?
