Team Corally RDX Touring Car
#346
We have the Delrin pulleys in stock now. If you want a replacement contact your LHS and they can call us or you can contact us directly. Either way is fine.
#347
hi, does this car have a center oneway as an option?
thanks.
thanks.
#348
nope
-one-way diff upfront
#349
RDX Kits in stock.
SP12M "Ahoniemi Euro Spec" Kits in stock.
Mini Assassin Kits in stock.
Check out dealer page on www.corallyusa.com for a dealer near you.
#350
How is everyone placeing the electronics? I have a gtx speedo and xxtra syn receiver.
#352
i have the receiver mounted on its side right behind the servo and my keyence mounted behind that flat, looks ok and i dont get any glitches
#354
Registered User
Thanks Pete now you know the right way to sucess,the Corally RDX,and see ya at the track,
Happy Hollidays to everyone of you
#356
#357
TESTING
Cars built and I have to say, what a quality build.
Great piece of engineering.
We have just done the first shakedown testing at or local indoor tarmac track, and the best lap was quicker than we have ever done.
So everything looks very promising.
Only one problem the thrust race in the diff broke, we have replaced them.
Does any have any ideas on the problem?
Are the ceramic ones better?
We are running ceramic diff balls in the Alloy diffs, has anyone run the Delrin diffs?
#358
I have the delrin diff pieces but I have yet to rebuild the diffs with them, I do know people who run them and they claim that the diff is smoother with the delrin pieces.
I too have a thrust bearing problem, and I have not tried the ceramic pieces for the diff, they are out of my price range.
#359
Sway Bar
Are you guys both sway bars? I didn't put mine on to see how it reacts. Rear end was real loose, so I wondering if I put the front sway bar it will really be loose. Is this a right assumption? Should I work without the swaybar then put the swaybars on after it gets setted up?
#360
i dont run the sway bars, instead i run 22 lbs springs up front and 17 in the rear.
putting the sway bar on will take grip away from that end of the car, so putting the sway bar on the front will make the car feel like you gave the rear more traction.
