Team Corally RDX Touring Car
#2192
Corallyusa is a good place to start or try Superior Hobbies
#2193
Originally Posted by JayBee
What are the 'must-have' pieces I should get? -JB
#2196
http://www.allstarhobbies.com/home.php?cat=408
#2197
part #'s
50% Arms-791074
Knuckles-79280
Tower-79239
black spring kit-79230
Diff rebuild-79161
As for the screw i would suggest getting a couple bags of the small parts assort. 76071
I would also suggest getting some toe spacers...
.05deg-79125
1deg-79126
Hope this helps!
50% Arms-791074
Knuckles-79280
Tower-79239
Diff rebuild-79161
.05deg-79125
1deg-79126
Hope this helps!
#2199
Yeah I forgot that..... LOL That thing is AWESOME! That is the only word that comes to mind.
I love to see ppls faces when they feel it for the first time.
#2200
I'm confused about the toe-in spacers. Are the .5 degree spacers supposed to be exactly half as thick as the 1 degree spacers?
I got a bag of the 1 degree spacers, but I think they're .5 degree, becuase they're thinner than the bag I got a while back to shim out the front of the car. Combining two of them is thicker than the 1 degree spacer, so that's not an option. They're absolutely, definitely not the same as the first bag I got though.
For what it's worth, this bag had the old Corally logo, and the last one I got had the new one. I don't know if they both said they're for the Assassin or not, but I got the one listed on the RDX parts page both times. COR79126.
#2205
Okay, so I'm slightly losing it I guess. All of my shims are right around .80mm, as you stated. But, it appears that two different styles of washers were used for the shims, one with square edges and one with rounded edges. Keep in mind the first two washers came from one bag of 1 degree shims, and the third washer came from a different bag. They're all the same size, but look pretty drastically different to the naked eye. It's not as apparent when you're this close, but they still look quite a bit smaller.
