Team Corally RDX Touring Car
#2146
Trader Rating: 13 (100%+)
Originally posted by Brian McGreevy
If you're going to run outside now but plan to run on the rug later, I'd suggest getting the 0166UK kit. It comes with the 4 degree blocks and front diff. I have been using that on carpet/foam on low, medium, and medium/high bite and it has been awesome. The 3.5 mm topdeck is a nice feature of the Carpet spec, but not essential. Jeff Dayger finished 2nd in stock at the carpet nats with a UK kit (3 mm chassis plates).
As far as bang-for-your buck goes, you can't beat the Carpet spec, as you get the X-hard 75% arms, 4 degree blocks, 3.5 mm topdeck and silver spring set. If you got this kit, you would want to get the Black spring set for rubber tires and probably the 3 mm topdeck, but that depends on how high the grip is at your track.
So I get the Carpet kit, 3mm top deck, black springs?
#2148
Sold.
#2149
ive been sold for 4 months....now only if money grew on tree's
#2151
Re: GTX Wiring
Originally posted by Brandon Melton
If any of you guys run the GTX in the car, could you please post a pic of your electronics in the car (if it's neat of course). And if you somehow got the power cap in it somewhere, try to have the pic show it. Thanks.
I don't have a picture but I run the GTX. I took a piece of lexan and cut it the width of the Speedo and the length of it plus about another 3/4 inch to shoo goo the Cap down.
Then I just slide the whole thing in with the wires facing forward. The cap sits under the topdeck. Depends what receiver I guess but it works perfectly. If you can follow that description. hehe.
Jeff
#2153
Originally posted by SpeedDesignz
Welcome to the wonderfull world of Corally !!
your gonna love this car Chris.
#2155
"New Inside Scoop"
Mike Bruce incognito caught testing the Mi2 with Schumacher's very own Teemu Leino
j/k....But it sure does look like Mike
#2156
what Extra Parts should I stock up on? and where to get them?
I'm planning on getting the RDX,
What parts should I stock up on incase something breaks?
or what parts are the weakest on the car in case something
does break?.....
Also, can someone list all the websites where
I can order parts ASAP just in case I need them ASAP
p.s. How hard is it to build this kit?
I've built the Assasin before, will it be just
as tedious?
does break?.....
as tedious?
#2157
mike bruce
pw- thats his twin!
#2158
Re: what Extra Parts should I stock up on? and where to get them?
does break?.....
as tedious?
does break?.....
as tedious?
Same as any other car for spares.... arms, shock tower, steering knuckles, king pins for C-hubs, belts, screws, etc.
CorallyUSA website also has Parts List with Part Number, description and an image if available. Hope this points you in the right direction.
Jeff
#2159
does break?.....
as tedious?
does break?.....
as tedious?
The only item I have broken so far however is one steering knuckle.
I cannot comment on how this car is to assemble compared to the Assasin cause I have never built an Assasin but the RDX went together better than any other car I've ever built (including X-Ray).
#2160
i need to know what the dimension of the bearing that are in the aluminium stering block??? the one on the top (litle one)??
Later!!
Later!!
