Team Corally RDX Touring Car
#2041
Bear, it was shipped by Postal Service. You should see it in the mail. Cheaper for you.
Jeff
Jeff
#2042
ok,thats cool!
#2043
which of the three kits is the best kit
uk kit
us carpet spec
high performance kit
uk kit
us carpet spec
#2044
Best>/?
Wall street
depends upon where you run the most and your ability
Asphalt.. get the US spec kit if your track allows one-ways.. definatelly the fastest way around the track
Carpet I'de get the UK kit has diffs.. works good everywhere and if youre a intermediate driver you'de like this the best works good on asphalt too
The carpet kits is carpet only.
If you plan on running both asphalt and carpet get the US kit and order another diff set with it..
Other bits to get would be 4 degree caster blocks (if you order the US Kit it comes with 2 degree), a few pairs of hard A-arms, black spring set. 1.3m pistons (2 pairs) a couple of pairs of plastic steering blocks,.rubberneck bumper. The one tha comes with the kits is a bit whoosie. AE tc3/4 spring perches.these are lower than the stock ones. so you can really slam your car especialliy if you use the silver springs.
Luxury items would be ceramic bearings, silver spring set (for carpet) 64 p 104t spur gears, Aluminum steering blocks., 2 degree rear toi in hub carries and corally assasin weights to make weight at a sanctioned event.. the car build light mine came in 80 grams underweight.
Bodies I've tried that work good is the protoform stratus 3(with the bumps on the hood) , protoform alfa, protoform mazda 6, and cadillac cts.
welcome to the RDarkX-side!!!
#2046
uk kit
us carpet spec
uk kit
us carpet spec
00166 Standard One-way Kit: one-way, 2 deg caster blocks
00166UK Double Diff Kit: double diffs, 4 deg caster blocks
00167 US Carpet Spec: stiffer topdeck, silver spring set, 4 deg caster blocks
There is only ONE US Spec kit and that is the 00167 which is for Carpet Racing. The Standard kit contains the one-way.
Just choose depending on what you run the most, weather it is asphalt or carpet and then what you like to drive with. If you won't use the one-way ever, then get the UK kit. If you mainly race carpet then get the US Carpet Spec.
#2047
Re: NEW PRODUCTS IN STOCK
Originally posted by CorallyUSA
GP3700 Race Packs are available!
Corally MMS-3 Speed controllers available!
Optional 1.6mm Swaybars available!
2.4mm Graphite Chassis GP3700 compatible available!
2.9mm Graphite Chassis GP3700 compatible available!
3.9mm Milled Graphite Chassis GP3700 compatible available!
3.4mm Top Decks available!
Graphite Battery Strap GP3700 compatible available!
#2048
Do the 4 degree castor blocks work the best in general? Do any of you RDXers ever use 2 or 6 degree blocks? I'm planning on getting the one-way kit, but it comes with 2 degree.
#2050
Thanks! I may also get the thin chassis and spool for outdoor racing (at least the spool).
#2052
Re: Re: NEW PRODUCTS IN STOCK
Originally posted by dawgmeat
will the carpet spec chassis be compatible with the3700's or do you have purchase one of these new chassis?
Jeff
#2053
brown-winghouse rocks! i will be in orlando next week so we will check in on the girls.
bear-you will like the spool. The car will be super fast and easy to drive....yep...sweet like the winghouse girls.
#2054
or the blue stilly girls.....whatup TJ
