Team Corally RDX Touring Car
#1561
Yeah spools are usually real sweet outdoors. I have never really used them on carpet though. It tends to make the front end "fight" itself sometimes in certain conditions. I usually prefer a one way. If your setup is right, they are still very easy to drive even on the tightest of tracks. Spool do give some awesome rip of corners though.
-Korey
-Korey
#1564
Info on the Spools
bump!
Thanks a lot for the information on the spools.
This forum and thread is awesome.
Let's keep it alive!
#1566
Not a problem Mark.........
Also like to welcome Sushi Boy to the Corally Racing Team. Good luck at the Regionals this weekend.
Jeff
Jeff
#1568
Regional Moderator
Here a question for you guys...
I am running a one way in front and I am having a problem with the belt skipping off the front one way. Last night it actually cost me a place in the a-main.
I am running the belt tentioner in the front, and the layshaft is all the way upin the middle of the car.
Anyone else heard of this? My belt came out of the box really loose....
#1569
Blacksami where are you!!!!
#1570
Just to followup on the diff problems I was having before:
I rebuilt the diff using a new thrust washer which was properly greased this time, and it worked like a charm. I'm still fairly certain neither of mine were greased when they were pre-assembled (they both came out very dry) but a guy at the track who just bought his RDX said he got all paranoid after reading my post, and tore his car down (during its initial build) to check. His thrust washer had white grease on it, and worked just fine out of the box.
Anyway, thanks again to everybody for all the help and tips and everything else.
#1571
Seems that all the pre-built difs are having this problem these days...maybe it's a rush in the build at the factory. People noticed it with the new Xray too. Before building my RDX, I check the thrust and greased it anyway....i'll do the same thing with the Xray I receive today.
#1572
Whenever I get a new kit I always go over any prebuilt assemblies.
Its a nice gesture on the part of the manufactere to do pre assemblies. but It seem especially for race kits that it is entirely unneccesary
I can understand for rtr maybe. but as a racer I want to take my time a build everything...
Every part must be fit properly and adjusted to the correct spec. .
#1573
Another Success Story....
First time out with the car last night. What a great car!
3-4 tenths faster right off the bat!
Broke a diff screw in the A-Main I "stole" from kansasracer (see previous post), called Corally this AM, new parts are on the way. Now thats SUPPORT!
Great first time outing. But if anyone else asks at the local track, the car is terrible, don't anyone buy one....
I doubt the broken screw was anything more than a fluke, or maybe I had it too tight? The diffs are so smooth you'd swear they were loose.
Thanks Ken, Rob, and Jeff at Corally for the quick service and advice.
#1574
Assortment Cases
Added a new product to the website. It is the clear little parts assortment cases.
Added Tosolini's setup from the ROAR Carpet Nats.
Added Rob's setup from the Novak race for Rubber Tire Carpet.
Glad everyone is getting the diffs figured out. A little touchy but once done right, nothing but butter smooth. Like someone mentioned, building a bunch of diffs for kits can have a couple problems. Always a good idea to check everything yourself to make sure it is all done right, the first time.
#1575
Re: Another Success Story....
I also broke a diff screw this past weekend. I'm guessing I must have had my diff too tight as well? Nice to hear that they are sending you a new screw. I didn't think to call them about it, figured it would boil down to user error.
