Help! Flywheel Stuck!!!
i used soem threadlock to keep the shaft in place...but i put oo much and dired up keeping the flywheel stuck...please help!
heat up the shaft with a blow dryer then trying undoing it again..
k...lets see if it works...have u tried it?
if you used tamiya thread lock, then soak it in metho for say, half a hour. it should loosen right up. if you used some super hard drying cr@p like threadlock brand threadlock, you are basicly screwed if you used too much. use the tamiya stuff. it holds all screws in place just as adequatly and it issimple to remove, use metho.
o well...i used a mini-hammer n knocked it out =)
