NOVAK BALLISTIC 7.5 BRUSHLESS MOTOR
Brand New Novak ballistic brushless motor. I am going a different direction with my racing and don't need this motor.
$69.99 shipped in USA
This is the Ballistic Brushless 7.5 Turn Motor from Novak.
7.5T Recommended for Off-Road Medium Traction operation
and Backyard Basher conditions.
FEATURES: Completely rebuildable allowing upgrades or replacement of various
parts
Easy to adjust timing assembly
Meets ROAR and IFMAR specifications
12.3mm nickel-plated sintered neodymium rotor for maximum
performance in high-temperature conditions
0.125" (3.2mm) pinion shaft accepts all existing pinion gears
Sensor-based for excellent torque and low-speed driveability
Compatible with the Novak GTB and Slyder electronic speed controls
Heavy duty solder tabs
INCLUDES: Ballistic Brushless 7.5 Turn Motor with sensor wire and instruction
sheet
REQUIRES: Installing in vehicle and connecting to ESC
SPECS: Watts: 340
kV: 5800 RPM/volt (unloaded)
Sensor Harness Length: 9" (230mm)
Motor Size: 2.07 x 1.41" (52.6 x 35.8mm)
Motor Weight: 6.6oz (187g)
Magnetic Material Operating Temp:* 392°F (200°C)
* Motor is not capable of operating at 392°F (200°C). The recommended
operating temperature is 160°F (70°C)
parts
sheet
SPECS: Watts: 340
