Tuned pipe too close to fuel tank?
I'm not sure how close is too close when it comes to the pipe being next to the fuel tank. I just put a new Dynamite 086 pipe on my Ofna Picco buggy. The pipe isn't touching the tank, but it's really close. If I pull it out it seems like it stresses the spring coupler and I don't know if that's going to cause me to lose the seal. Anybody?
those 086 pipes are pretty fat. i have removed the header and give them a little tweak to cure this problem before. basically you bend the header slightly and it will give a good line with the tuned pipe. dont take much so just be easy with it.
If you are going to do that put a peace of automotive fuel line in the header so you don't kink it.
You could always kick it out just a tad with the front pipe mount if your that worried about it but you have nothing to worry about
You can use this. This is what I used for my real car on my valve cover next to my turbo manifold.
http://www.hrpworld.com/index.cfm?tp...action=product
I had this issue with my 086 in my RC8T, and yes, it will melt the tank..it doesn't melt silicone tubing because the tubing melts at a MUCH higher temp( somewhere between 500˚-600˚F, I believe ) than plastic.
I used some Parma silicone servo tape, as an insulator, and aluminum tape over that as a reflector, and stuck it to my tank on the pipe side and most of the tank, leaving a 'window' on the front driver's side corner so that I can still see my fuel level.
I also run my header the little more parallel ( basically, where the coupler meets the pipe is raised up and away from the engine, instead of laying it down closer to the chassis ) this pulls the front of the pipe away from the tank.
Hope that helps ya!
Hope that helps ya!
I think I might try to straighten out the header a little bit. I'm glad I didn't try and run it yet, I knew it didn't look right, and I'm sure a melted fuel tank would ruin the day. Is there any chance that the fuel would have gone up in flames if that did happen?
I always just go to the local Stock car race shop and buy a roll of self adhesive insulator tape. Once it gets old, peel it off and put a new layer on. Easy as that.
The melting point of the "softest plastic" is about/around 200-250F. I know for a fact fuel tanks are made of a stronger higher melting point plastic ESP. being a "FUEL" tank.
I'd say a plastic RC fuel tank is in the 500-600 degree range before it melts.
Not to mention, you have LIQUID in the tank "fuel" that wont allow it to melt.
Ever hold a lighter under a plastic bottle with liquid in it? It will eventually boil the liquid and NOT melt the plastic.
If anyone is melting fuel tanks with the front of an aluminum 086 or any aluminum pipe for that matter,(not even the header part) you have other issues you should probably attend to first like buying a new engine cause the one your running is shot
Well I guess my rc8 got to 500-600 degrees (not likely) because my muffler would touch it and you can see the melting spot as it was getting deeper and deeper. You ever cut plastic with a soldering iron, that is what a hot muffler essentially does to the fuel tank and I am sure it could do that without boiling the fuel. A lighter would not do that to all liquids as different liquids have different boiling points. I am sure you know that.
I tweaked the header a bit and it looks a lot better. Originally there was only enough clearance for a sheet of paper, no way I could squeeze fuel tube in there. I've had the pipe melt a bit of the body before so I thought it could damage the tank as well. Thanks everyone, should be good to go now.
Reflectivei tape
Hi guys.
I don't know if it's the same, but, isn't this basically aluminum tape??
At Home Depot (Home Center, cause I'm not promoting HD even though I have spent enough money there to build a house (I actually built 1/2 a house from there))
Anyway.. (rambling ) In the building section, I think it is called flashing. Aluminum tape is used to place over windows when they are being put in the walls.
I don't remember the price, but, I do know it exist because I have a roll or two.
Hmm. Maybe it wasn't Home Depot I got it from..
Scratch that. Wasn't Home Depot..
Anyway. Ahhh. The aluminum tape is used to install HVAC Ducting..
That's it.. I remember. Try HD in the HVAC Department (eventhough, that was not where I got it from)
Man...... Was that too much or what??
When you are on a roll, it just goes to the fingers.
too many years coding programs and secretary school???
Just kidding about the coding.. Doooooo
