CRC Gen-x 10 le gearing? ALso setup w/ novak smartbooster and mmp (standard version)
Just picked up my first carpet car on here (gen-xl) the other day and figured what the hell and snagged a CRC gen-x 10 le kit as well...
Now I may have missed it but there is no recommended gearing chart or samples of any kind and the few setup sheets I found make no mention of gearing and motor setups.
I'm running in a 1s lipo stock class, I have a Losi sensored 17.5t motor installed running off a mmp (regular) with a novak smart booster.
So really I have two questions..
Gearing for this setup. Im starting with some BST world GT tires (purple) med foam. Any thoughts on a gearing start point?
I will disable the LVC in the MMP since the Novak smartboost should handle these duties. Should I pull the center wire on the mmp or just leave it in as I'd assume it needs assistance from the booster as well? Any other thoughts concerning the mmp? This is not a 1cell edition.
Well I Got one answer.. unplug the center wire to disable the bec as normal..
Nobody w/ some gearing ratios? FDR? anything?
