EAMotorsports discussion thread
#1306
Mini- I have personally been running a full faced F brush with a red/red combo. This has worked for me almost everywhere. If you set the CE dyno up with torq steps you can see that this is the best setup in most cases. Amp draw doesnt mean squat in TC racing. I have had a stock mtor pull only 4 amps on my GFX and be a rocket. You have to gear the motor for the rpm it has.
#1307
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
mini
Me & EA found that useing harder springs on the F-lines made them fade about halfway into the race ,,, as you said over working the brushe, if you have a bit of arcing then run red/red this will cure the brush bounce at high revs
The grn/red combo is favoured for the monster!!! The roar on the other hand i suspect ,cos i have`nt had any roars yet with f-lines fitted! would be happy running the red/red or red/purple cos of the higher speed the roars develope
EA can clarify the roar bit though, as i say i`ve had no roars yet with f-line fitted as std
By the way mini are you still talking to me !! hope so
#1310
Cheers SS
#1311
Must try them spring combo's, didnt get testing 4499's against the F-lines as i've only got a limited supply left. I'll try several different spring combo's at the weekend and see and try 4499's versus f-lines.
If someone could tell me how to reduce the motor timing via the brushes it would be great.
#1312
Originally posted by MR JOLLY
Cheers SS
Cheers SS
#1313
Yeah it was the cells and stuff i missed, father said they were attempted to be delivered yesturday so went and collected it all. Will be building them when im back at uni.
Edit: and you gave me 21 brushes so if i want to try one on an MVP style motor with a 766 or something on the neg i can
#1314
Evo
These querys bye other racers are to be taken lightly re;;springs on the motor, what works for one might not for the other
Q)are your copper shunt with f stamped in the back??
#1315
Evo
Evo
#1316
berger
what do you think it looks like on my with 150 of the little buggers
EVOtech
If your at work you shouldn`t be on here
EVOtech
#1317
berger
EVOtech
berger
EVOtech
#1318
hey Eric,
Thanks for another great batch of motors, ill be putting in another order in a week or two.
Nick
Newark, Ca
Nick
Newark, Ca
#1320
RC
