Like Tree78Likes
EAMotorsports discussion thread
Old 01-23-2005, 11:01 PM
  #1261
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by EAMotorsports
P.S. Batteries will be in stock by the end of next week
...Woooo Hoooo... it"s about dang time ...
Hey Eric.. will you be doing any of the Intellect or IB 3600 cells in the future..???? Please say yes because these things Rock!!!!!!!!!!!
-Dave
JDM_DOHC_SiR is offline
Old 01-24-2005, 12:19 AM
  #1262
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
J-P
your answer is over geared & your batts, just get your new one in there
And you could of phoned me on sunday while you was at DMS ,would of guided you through the maze of `going fast`
By the way ,my dyno is the race track,
Originally posted by J-P
i run a monster that colin sorted out for me, using f-line brush's I run it up on the pulsar at 2v. it pulled 8amps, i thought this was high!! but i dont know any better any way out of curiousty i run an EA roar with 767's in and it only pulled 3.8amps at the same rate. im not sure of my results but if any one could explain the differance that would be great
i must say that the car didnt have much punch out of corner's but my cells are not the greatest. ( im getting new ones soon )
and was running at 7.7-7.9 ratio in a pro-4
thanks guys hope my info can help some others out
J-P
MR JOLLY is offline
Old 01-24-2005, 12:38 AM
  #1263
J-P
J-P's Avatar
hey colin thanks but i thought you was out!!
i thought i was over geared but was unsure about dropping to low on the ratio, i.e. 8.2, but i am well happy with the motors and so was some of the other guys at dms, i just gotta learn to get the gearing right like you said to me on saturday evening but its all a learning curve
still out side next sunday with the EA roar
J-P
J-P is offline
Old 01-24-2005, 12:43 AM
  #1264
MR JOLLY's Avatar
This is EA`s recomendation on new motors
To Dyno a New Motor
When you order and receive a motor if you are going to dyno the motor before running it please follow the following instructions. Take the motor out of the package and put it on a motor break in box at 2 volts for about 30 seconds just to reseat the brushes after shipping. Then spray the motor out with motor spray (without removing the brushes) and allow to cool and dry then dyno. If you don't follow these steps you won't get accurate readings.
1) i don`t run them in (that`s me) cos the 1-2 laps i do would of seated the brushes by then
2) i don`t do dyno`s, reason is i can`t be arsed & the track is my dyno
i have never done anything to the F-line??striaght out of the packet into the motor, no drilling,no sanding,no cutting, they just work
russm8
Q) after cleaning it for the first time, did it do it again??
Q) was this on on motor that came with F-line as std??
If i thought the F-line were a bit dodgey i wouldn`t of gone over to the F-line`s. the 767`s EA has used were good, but i have faith in the F-line`s ,i used to use putnams last year to get the `power` i get that with the F-line plus the wear on the comm is soooooooo much better & i can do 3-4 high speed races instead of 2-3,
But i know the F-line will not work for every one, every one is different some like 767`s others don`t,some like putnams some don`t, etc etc etc
EA
the motors in transit?? the way your wife packs them is real good cos they are in tubes it is less likely to be damaged & off all the boxes that have arrived none of them have been crushed
mini & russ keep us posted
MR JOLLY is offline
Old 01-24-2005, 12:45 AM
  #1265
MR JOLLY's Avatar
J-P
Learning curve?? it`s a steep one at that
MR JOLLY is offline
Old 01-24-2005, 12:55 AM
  #1266
MR JOLLY's Avatar
j-p
YGPM
MR JOLLY is offline
Old 01-24-2005, 03:32 AM
  #1267
Hi Colin, Yes the motor was great once i cleaned it and it was a new motor with the f-line brushes . Just thought i would post as i thought that maybe it could have been a problem for others as i thought there could have been a protective film on the com brushes or something.
I have no problems with the EA motors at all tbh i think there GREAT :P
I just think that i was unlucky on sunday. Next time i will run any new motor in for a few mins before i run it to reseat the brushes.
russm8 is offline
Old 01-24-2005, 05:08 AM
  #1268
I reconmend using Zubaks speed juice for breaking in motors. Its what I use here at home on all the motors I build.
On my site you will see that I reconmend also running a motor at 2volts for a few hundred seconds when you recieve them...especially people overseas!! When getting shipped I pack them as well as I can but with the motors being bounced around sometimes it may unseat the brushes. There shouldnt be any film on the comm's or brushes. I clean everything after dynoing them to ensure they are perfect when they arrive to the consumer.
EA
Cheers Eric, i might have to get colin to get me some of those drops. The last motors I got I took apart and skimmed before running them and then re seated the brushes, wasnt taking any chances.
Tell me do you zap the can of your motors? would me zapping them before I run them be beneficial?
And another question a bit off topic that some of you US guys or uk guys may be able to help me with, do you know of anywhere that I could order an 1/8th of an inch long series hand reamer??
Also I wont be dynoing any new motors, cos they are always good. I just intend to dyno one ive had a while and try different brushes, springs and see what my zapper does to the motor.
minibutmighty is offline
Old 01-24-2005, 05:15 AM
  #1269
MR JOLLY's Avatar
mini
EA is sending me some speed juice & lube with the next order going out today (i hope) or tommorrow
MR JOLLY is offline
Old 01-24-2005, 05:24 AM
  #1270
That be the order with my roars?????
Old 01-24-2005, 05:39 AM
  #1271
trackdesigner71's Avatar
Buddy,
Taking a little off the edges reduced the overlap which drops the timing a little. I will take away RPM but will add torque, watts and eff. To give an idea how much to take the width of a comm slot on the comm is 2 degrees. So if you took that width off each side you would be running a 20 degree stock motor!! But it will have tons of rip!! The higher the timing the more rpm and ampdraw you have.
Hope this helps
EA
Mr Anderson, (why do I have scenes from the Matrix flashing through my head all of a sudden)
I sent you an email
trackdesigner71 is offline
Old 01-24-2005, 05:41 AM
  #1272
MR JOLLY's Avatar
Errrrrrrrr no!
EA is expecting them this week (i hope) fingers crossed
this has monsters & 19t`s on board. 1 for rod, got to keep him happy
MR JOLLY is offline
Old 01-24-2005, 05:53 AM
  #1273
email sent Mr jolly regards another issue.
Old 01-24-2005, 07:19 AM
  #1274
MR JOLLY's Avatar
mini
when i have the reply from paul@ BRCA i will notify you
MR JOLLY is offline
Old 01-24-2005, 07:44 AM
  #1275
raving-monkey's Avatar
colin, you have PM
to the EA users out there.....has anyone had any good results using comm drops? certain people have told me it can make the motor worse (smears the carbon around or something dodgey like that)
although i have been given a "tip"..i noticed Eric used comm drops to develop the F line brushes..how does he actually use the comm drops?..just put a drop on the comm and give it a spin?
raving-monkey is offline
