drifting question >
drifting question
drifting question
Old 07-12-2004, 05:58 PM
Default drifting question
is drifting better with 4 wheel drive?
Mxracer1990 is offline
Old 07-12-2004, 06:39 PM
corvettecrazy's Avatar
yes
corvettecrazy is offline
Old 07-12-2004, 06:46 PM
FW-05RR's Avatar
I don't believe their are any current touring cars on the rc market that are 2 wheel drive unless you make your own by cutting a belt or cutting your shaft....but yes drifting is better with a 4 wheel drive it gets boring after a while though
FW-05RR is offline
Old 07-12-2004, 06:49 PM
DOMOisCOOL's Avatar
Yes drifting is better in 4wd (RC wise).
However, it is hard to drift nitro cars. Since the response time isn't really instant. To add to that, it will be very hard on your clutch.
DOMOisCOOL is offline
Old 07-12-2004, 06:56 PM
you could take out the frint axles but i thought i looked at an electric car and it was designed for drifting i forget the brand but i thought it said 2wd but im not sure
Old 07-12-2004, 09:04 PM
I drift my nitro MT (stadium truck) and it really isn't that bad on the clutch. It's not great on it but I have found I get worse wear doing other stupid stuff. (that isn't drifting)
If you have an MIP clutch( the one with the 3 holes) using the first hole, it grabs really early, so you do have a pretty good response time, although nowhere near what electrics response time is.
Old 07-12-2004, 09:14 PM
DOMOisCOOL's Avatar
You must be thinking about the Yokomo MR4TC-SD Drifter Chassis. It is 4wd.
Old 07-12-2004, 09:16 PM
Tek Nickal's Avatar
If it were 2WD then it would be really hard to control. It would be so loose, you'd spin out once you start to counter steer.
Tek Nickal is offline
