Motor AMP Draw?
Old 07-12-2004, 09:58 AM
Default Motor AMP Draw?
Can anyone provide me with some info on how many amps a Reedy 19-Spec Ball Bearing motor should be pulling?
THank you
atlrcracer is offline
Old 07-12-2004, 12:56 PM
Charlie O's Avatar
Call Team Associated, and get the reedy motor department, they should be able to help you.
Charlie O is offline
Old 07-12-2004, 01:38 PM
PitCrew's Avatar
Probably around 4-6 amps at 2 volts on a Pulsar. No load (no fan)
PitCrew is offline
Old 07-12-2004, 02:02 PM
Thanks guys...i am looking to experiement with some lipo packs. If this motor will only pulls 10a..then I can use lipos...
Just a thought.
Old 07-12-2004, 02:14 PM
Regional Moderator
UnderDaHill's Avatar
If your talking about in a car then maybe 20-30amp with larger spikes off the line or during crashes.
No load at 2 volts will stay under 10 amps but even no load (read not in a car but just spinning free) at 7.2 volts it will go over 10 amps in some cases.
Give us more specifics of what you are trying to do and somebody may be able to point you in the right direction.
UnderDaHill is offline
Old 07-12-2004, 02:48 PM
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
If you are using a sedan and you tap the wall expect that amp draw to spike out at 60+ amps. Under normal race conditions without hitting anything you are looking mainly between the 20-40 amp range.
Kraig is offline
Old 07-12-2004, 02:50 PM
GundamWZero's Avatar
Do you run with Birdman motors? I am trying to see if I know you fron a certain place......
GundamWZero is offline
Old 07-12-2004, 06:02 PM
The motor will pull way more than 10 amps in a car. Think about how long you run for....6 minutes on 3300s, lets say. Thats a 33 amp average discharge. Thats average, expect peak amp draw to be much higher.
RC Paperboy is offline
Old 07-12-2004, 06:53 PM
hmmmm...
Using the motor mentioned...and with a 26t pinion, on a 93t spur....at full throttle....I am only pulling about 11amps MAX burst....
Old 07-12-2004, 07:04 PM
Super Moderator
Kraig's Avatar
Are you just testing it on the bench? What is the output voltage of the battery pack? Those two things will have an effect on the amp draw.
Kraig is offline
Old 07-13-2004, 03:20 AM
Your motor will draw its maximum at 0 RPM from a standing start in a fully loaded car. ON the bench means nothing. Like has been said here, 20 to 40 amps is normal, with spikes if you hit something.
David Root is offline
Old 07-13-2004, 05:16 AM
so to accellerate your tires, driveshaft, motor arm, gears, all the rotating parts requires 11 amps. When you accelerate the car, thats over 1500 grams to accellerate. It will pull a lot more than 11 amps.
Old 07-13-2004, 05:28 AM
A good 19T will draw >100Amps when accelerating from a standing start and about 35 amps on average.
vassago is offline
Old 07-13-2004, 08:44 AM
Neil Rabara's Avatar
Default Re: Motor AMP Draw?
THank you
Somewhere between 8 and 11 amps with no load at 3V.
Neil Rabara is offline
