New Emaxx - RTR in the box - sealed
I have a new EMaxx RTR - not the brushless one - the one with two titans motors -
Shipping to 48 states only
$250.00 shipped to 48 states plus $20.00 shipping
This is the 1/10 scale electric powered 27 GHz radio controlled ready-to-run
16.8V Traxxas E-Maxx Monster Truck.
Equipped with dual brushed motors but all components are
built for brushless power-no driveline upgrades needed.
FEATURES: Chassis: 0.08 (2mm) thick composite with snap lock battery hold
downs and scaleable battery components to fit a variety of stick
or side-by-side packs
Drive: Four wheel shaft drive with Revo spec sealed large diameter
outer and center drive shafts
Motors: 16.8 volt Titan 550 size fan cooled dual brushed motors
Radio: 2-ch Traxxas TQ 27.MGHz, sealed receiver box for running in
wet conditions
running in wet conditions
Electronic Speed Control: Traxxas EVX-2 forward and reverse ESC with
three programmable driver profiles and training mode
Batteries: Two Traxxas Power Cell NiMH 7-cell flat packs with Traxxas
High Current connectors, 16.8V total power
Ball Bearings: Full set rubber sealed
Shocks: Eight oil-filled, composite bodied with red springs rubber
pressure bladders and double O-ring seals
Gearbox: Sealed
Differentials: Revo spec with X-ring seals to keep oil in and dirt
out, bevel gear design
Slipper Clutch: Traxxas's patent pending Torque-Control slipper
clutch
Transmission: Single-speed (two speed optional)
Tires: Treaded soft compound Maxx 5.9" (149mm) outer diameter 3.25"
(82mm) width
Wheels: 3.8" (96mm) diameter chrome 10 spoke (spokes are in groups
of two) 2.7" (70mm) width, 14mm hex
Bumpers: Plastic front and rear with kickups
Suspension: Adjustable Revo Spec sealed pivot balls
Caster: Adjustable, caster/toe-in refers to the angle of the front
suspension when viewed from the side of the car in relation to the
chassis
Camber: Adjustable, camber refers to the angle of the tops of the
tires from vertical when viewed from front or behind vehicle
Steering: Heavy duty dual servo bell-crank type with ball bearings
INCLUDES: 16.8V Traxxas E-Maxx Monster Truck oil-filled shocks, two motors
electronic speed control, painted body, tires, foam inserts,
2.4GHz 2-ch radio, two steering servos, wheels, instructions,
decals, tools, two 7-cell batteries and foam battery spacers
wet conditions
Gearbox: Sealed
clutch
(82mm) width
chassis
sorry tried to load pictures - wont load
PM me if you would like to see a picture... with email address.
Pmed
PM and pictures sent -
lots of lookers -
GREAT Deal
lots of lookers -
GREAT Deal
SOLD
thanks Robert
