3Racing Sakura Zero S
#1306
Would the Sakura XI rear shock tower be a direct fit for this?
#1309
Finally got mine in the mail this weekend.. put it all together.. and painted a new body specifically for this chassis.. check it out.. only issues im having right now are that the car doesnt turn very far left or right.. i noticed that i put the c-hubs on the wrong side but i dont know if thats whats causing it. I'll keep you guys posted.. here are some quick shots
#1310
#1311
Theas1an
it looks great!
could you post A FEW MORE pictures of the chassis?
I love looking at other ppls creations
it looks great!
#1312
If the front toe is set like at your car, the inner knuckle arm will very soon touch the lower suspension arm, thus limiting the degree of steering.
I hope this was understandable...
Greetings,
Christian
#1314
Built per the instructions, the Zero S does have a lot of toe-in. I ran it that way for a few races and i didn't have any issues with steering throw or the lack thereof.
I'm currently working on bringing the toe-in to something that doesn't look that severe. I was at the track when i started this, but i'll throw the car on my setup station and see what kind of numbers i'm at and where i want to go.
With all that toe-in on a VTA ride, i didn't notice any adverse effects. But i suspect i'm scrubbing off a bit of speed even though i'm finishing top 5 and turning some pretty consistent laps.
#1315
I adjusted the Toe-in .. much better turning ability now, also adjusted the camber to -2 on all four corners , wont be able to test it out on til this weekend though heres more pictures of the current setup
sorry for the poopy pictures , I have a crappy camera phone
#1318
@Theas1an
Check the location of the ball stud on your steering knuckles. Per the instructions it should be in the hole closest to the rear of the chassis. That may or may not have an effect on your steering.
I've never messed with that adjustment so brighter minds than mine can tell you what effect it will have on steering.
#1319
@Theas1an
#1320
Wow .. Ill give that a try, Ill do it now and will report back after friday night
