3Racing Sakura Zero S >
Like Tree2Likes
Old 12-12-2012, 06:19 PM
  #2206
what tooth pinion are u using? if u dont mind me asking.. m using a 34t and its very tight.... i think its actually decreasing the cars performance
sonspit is offline
Old 12-12-2012, 08:04 PM
  #2207
i have my esc in the opposite way with the motor leads on the outside... did i do it wrong? might seem like a silly question but this is my first kit.. i think we have the same esc also..sidewinder sv2.. does yours get hot quickly?
sonspit is offline
Old 12-12-2012, 08:11 PM
  #2208
Originally Posted by hotdogs
Is the stock spur on this vehicle considered 64 pitch?
What size pinion would fit onto this car without modifications or upgraded parts?
I am thinking of club racing with a 17.5 motor
pinion size--20t 48 pitch
sonspit is offline
Old 12-12-2012, 08:26 PM
  #2209
Originally Posted by OverGeared
The guys here might be able to help if you could tell us what motor you are planning to run the car with.... (how many turns or how much kV / spec or modified)...
im running the stock spur.. with the castle creations 6600kv 4pole motor. what pinion should i use? i installed a 34t but its extremely tight ..so tight that the car doesnt move freely
sonspit is offline
Old 12-12-2012, 11:17 PM
  #2210
There should be a slight gap between the pinion and spur use a piece of paper to help set the gear mesh , too tight will overheat the motor and could possibly make it slow as you mentioned but the nimh batt could contribute to that as well, too loose and you'll strip spurs
thefan is offline
Old 12-13-2012, 08:43 AM
  #2211
Sakura s zero is good kit and my first kit is sakura s zera now i use sakura x1 DH u oso can use the spur 64 pitch 80t I oso got race o timing I use viper esc
MICHAEL LIM is offline
Old 12-13-2012, 09:26 PM
  #2212
Got mine just now.
Will get it assembled tonight.
ericmaxman is offline
Old 12-16-2012, 07:10 PM
  #2213
matt*strike's Avatar
Trader Rating: 41 (100%+)
Had a great first day of racing. Only change I made was 4000 in the front diff. And loosened the belts a little.
I could only get a 34 tooth pinion on wish I could get a couple more outta this thing. It was a tight squeeze with the verticle motor mount ver 2.
matt*strike is offline
Old 12-16-2012, 07:48 PM
  #2214
ta04evah's Avatar
With a little bit of dremel work and fitting a smaller spur gear I've managed to squeeze a 43 tooth pinon on.
Cheers
Rob.
ta04evah is offline
Old 12-17-2012, 02:03 AM
  #2215
Are you using the 3racing spurs.
Old 12-17-2012, 02:51 AM
  #2216
Default ackerman steering
can you add ackerman to the zero,I am trying to get my car to turn in a little quicker ? it wants to push a little to much when entering a corner .thanks Tom
tntracing is offline
Old 12-17-2012, 06:46 AM
  #2217
ta04evah's Avatar
No, I'm using Robinson Racing machined spur gears.
I also had to dremel off 2 of the 4 "lugs" on the alloy spur gear holder so I can use almost any brand of spur gear that doesn't have the extra holes.
This means I only have to use 2 screws to hold the spur gear assembly together.
Cheers
Rob.
ta04evah is offline
Old 12-17-2012, 08:44 AM
  #2218
to change Ackerman you change the size of shim under the cap of the steering arm where the links attach to the center. there is an end screw. for more it's less shims. I'm running mine glued with 6mm of shim for as little ackerman as possible.
jdeadman is offline
Old 12-17-2012, 04:01 PM
  #2219
Cheers
Rob.
Buy lugs do you mean the small raised sections on the holder. ?????
Old 12-17-2012, 06:35 PM
  #2220
ta04evah's Avatar
Yes, the small raised sections, or you can drill extra holes into your spur gears.
I chose to dremel them off as I don't have a drill press, and don't trust myself hand drilling the spur gears.
With 2 lugs & 2 screws instead of 4 holding the spur gear I've run a 13.5 blinky in the car and it all hung together.
Cheers
Rob.
ta04evah is offline
