best way to clean clutch bell bearings? or any bearings in general?
Hi.
I use normal non-sealed clutch bearings, and they last several gallons of fuel. You just have to lubricate them approx. after every 6 tank of fuel. When you use the non-sealed bearings, you can put oil (I use normal gearbox oil from 1:1 cars) true the outer bearing (when the car stands vertical), and the oil will run down to the inner bearing.
I know you have to check the clutch from time to time by removing the engine from the car, but you can have several practice days this way, without waste time on changing bearings.
If you use a sealed inner bearing with the sealed side towards the clutchshoes, you don't get oil on the shoes under the lubrication.
I don't clean my clutch bearings - no need to
#20
do you mean remove the seals and blast the grease out and use light oil doesnt that make them not last ? i mean il get the grease off the outside and than put a dab of oil on the outside of the seal.
#21
i would recommend this engine to anyone, why do you ask?
many thanks for the comments, i have some decent clutch bearings but i live in the UK and parts i think are generally more expensive hear. a set of clutch bell bearings from losi costs nearly £10 from my local model shop!
thanks for the advise
lewis
