POPPING GLO PLUGS
POPPING GLO PLUGS
Hope someone can help.I have a 359+21 and every third or fourth tank of fuel the glo plug goes bad.It will run fine the until you shut it off and then when you go to restart it doesn't.Tried sealing the motor with silicone,not letting it run out of gas and shutting it off by the flywheel nothing seems to work.Somebody told me to replace the con rod but there is no play what so ever.Motor was running fine then out of the blue it started doing this.I also have a JPTL3.12 that does the same thing.
The coil is still there and it looks kind of dark when i pull it out.Im using a black novarossi 7.
Black and wet with fuel, running too rich. GP that is hot, Fuel is cold it would warp the coil of glow plug. If it blows out Running too lean. You want a clean coil a bit of ash on the coil your close. .12 engines run good with hotter GP.
In the .12 i do run a nova 5.in th .21 i run the 7.When the motor is running it runs like a bat out of hell.Temp about 250 degrees.Its just when you shut it off and let it cool down and then go to restart it won't because the glo plug went bad somehow.And i never leave the piston up.
Things to try:
Go to a Nova 8
Get some Sirio 7's (or Werks) amazing plug, works great in Novas.
Find some GRP 7's.
Try OD99T. Not as good as the others but dirt cheap.
As for the rod, if this thing has a couple gallons or more on it, change it NOW!
Engine Hard to restart after it cooling down. You running at 250F is running lean. When the engine cools it change a bit. Your trying to start lean. Richen you HSN by 1/2 turn and try again. Then retune for optimum performance. Cold engine richen it out and retune, like running in afternoon @ 250F, let it cool till tomorrow, 1/2 turn on HSN then retune for the day!!
any other turbo plugs besides sirio and grp?they seem alittle hard to find.i have tried different plugs in nova's before like odonnell and os and they did not run as good its almost like the other plugs didn't seat right and caused an air leak.
Piccos are good too.
Try a Nova ultra 8.
There is your problem right there. Nova plugs used to be great but they went in the toilet about 2 years ago. I hear they have fixed them but haven't got a new batch to try yet.
Things to try:
Go to a Nova 8
Find some GRP 7's.
Things to try:
Go to a Nova 8
Find some GRP 7's.
If other plugs do pop out as well you should check the play on the rod but also the main bearing.
When glow plug dead too quickly,
Usually because of excessive vibrations :
1. main / rear bearing need replacement
2. conrod need replacement
If the engine is relatively new :
3. nitro percentage is too high
4. engine is running too lean ( too hot ).
