kyosho inferno ve esc problem
my sons inferno ve stopped working today,at first it would run a little then shut off but the steering servo still worked,it seemed if you would move stuff around it would work try and run it agian same thing would happen,after a couple of times doing this it went dead altogether no power to the wheels or steering and the light doesnt come on the esc,so does anyone have any ideas does kyosho have a warranty and how long its covered,or do they have a exchange plan like traxxas
what size lipos you running
i have the ve ,and im just waiting for mine to do the same,i think u should just upgrade ,dont worry about getting a new one
so are you saying they have problems with them do you have any links were they are talking about it,and if i would upgade do i need a motor to or just a esc,i found the castle monster esc for 160.00 but will it work with the motor
2-7.4 5000 mah
so i talked to kyosho today and they said to send it in and they will send another one out and they do have problems with them.he said to send the brand of batteries and the c rating in to i was using venom 2 cell 5000 mah 30c is that ok for this car or should i say something else ?
Yes, those batteries are perfectly fine to use and to tell Kyosho you are using them. The orion speed control is a great speed control...very smooth for a sensorless controller...but every once in a blue moon there may be a problem. The great thing is Kyosho will stand behind the product and warranty it for you .
great info.....
Hi RC8Tedad,
dion
