X-ray NT1 - What engine Exhaust Combo???
Getting back into nitro and getting X-ray NT1...
Want to hit the track,
What is the fastest engine and exhaust combo you can get?????
I was thinking a nova rossi 353.....
Any suggestions??? What do the pros use??? do they use JP?
I will use for hard line parking lot speed runs alot of the time too...
If you want a reliable and powerful engine RB is the way to go
If your going to buy an RB Engine for your NT1 buy the new ////RB T|10rc, it comes as combo package with the new RB 2659 pipe
Both the ////RB T|9rc and the ////RB T|10rc and reliable and powerful, but the T|10rc has a bit more top speed.
If i were you i will buy the RB t10 rc engine it is a very reliable engine compared to other brands, great performance and fantastic speed i am very happy with it
What is the ideal pipe to go with the novarossi??
I did not think Rb was better than novarossi....
Am i wrong???
Am i wrong???
If you have a RB engine, on the carb rubber bellow (the black one) you can see the letters (NOVA) that means Novarossi and RB engines are made in Italy too.
You can see it in the pictures
Hello!
..the RB 2659 is the same of the Nova 2652 in the inside.
If you want more bite-power you can buy a Nova 2660 or a Capricorn 2662
This 2 pipes has almost the same internals and the same conical tube.
Max's 2664 also has the same components but an "old style" tube. Infact this pipe mounts a traditional 8mm tube (this is the external diameter) instead of the 10mm (Cap and Nova) but it is also conical. Obviously less conical because of a mesure issue but conical
If you want to try something different I can suggest you to buy a Jp-Gimar (HIPEX) 2654. I used this pipe (in combination with MaxPower XXL3 bl) in the last round of the Italian Championship.
I race in the F1 cat. and I managed the final with this pipe.
I also tried a Nova pipe in the previous race days but I choose the 2654 because of the consuption. With the Nova pipe I can't do 5 minutes with a tank but using the JP I did 5.20 mins. ..and the power its the same
(ps:ever used a medium conical manifold)
the fastest engine is the Novarossi Flash 3 tuned. When you buy Nova you get a fast engine. All engines are fast and you don`t have to be lucky as is with other brands. with other brands sometime`s your engine is fast end sometimes it isnt. But Nova have the quality with all their engines that is the differance.
Rb are also fast but the take a long time to free up and get the speed is my experience. If you want the best buy an Flash tuned ceramic.
Get an conrod and bearings to replace when broken in.
Greetz JW
Greetz JW
http://www.rc-toro.com/product_info....4ef7c6f69c2b64
Get the engine you like and that you can get parts for ....there all good different power bands all comes down to tuning driving style and car setup
Greetz JW
Greetz JW
They take a long time to free up, because the piston has a very tight fit around the sleeve, they use to keep locking up (TDC) for a long time when you are trying to start it when it (the engine) is cold. That is a good sign and it means that RB engines (in this case) last longer then other engine brands that free up quicker
Yes the last, i have 2 RB one murnan M3 and a T10RC , they both are one seison now and still lock on tdc even when hot.
Greetz JW
Greetz JW
