Xray RX8 1/8th Scale >
Like Tree33Likes
Old 03-30-2012, 08:56 PM
  #961
YLLIB's Avatar
Originally Posted by RC MARKET
Conv. set updated
Thank yuo
YLLIB is offline
Old 03-31-2012, 03:13 AM
  #962
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
What exactly does the conversion kit do to the car to improve it?
Jamison R is offline
Old 04-03-2012, 10:32 AM
  #963
I just installed the new steering block, there is 2 ackerman position as MRX5, the servo travel distance less than before to reach the same turn angle.
I didn't buy the rest because the suspension mount in graphite doesn't help much I think, it just a fancy stuff.
I cut the radio plate myself too, and using Aplus clutch.
beebone is offline
Old 04-03-2012, 11:10 AM
  #964
66mm front 73mm rear. what shore front 35? 37 rear?
We run a little softer 32 fronts 35 rears ... But we have 2 of the most "tennis court" smooth 1/8th scale tracks in the country !
(One of them is hosting the 2012 Onroad Nationals)
CFowler is offline
Old 04-04-2012, 02:25 AM
  #965
Jamison R's Avatar
What is a good reciever pack for RX8. Is lipo common in Nitro 1/8. Also what are some good servo's? I am coming from an electric touring background, excuse the ignorance.
Old 04-04-2012, 02:27 AM
  #966
Jamison R's Avatar
Old 04-04-2012, 07:51 AM
  #967
I run KO 2.4... you dont have a lot of room in the receiver box so it has to be small. You can run lipo, some people do.
We try to get the car as light as possible and then put all the weight in the bottom of the car to improve handling. Using a NiCad pak puts that weight in the bottom of the car... (you still may have to add more)
Car looks good !
ATS Tyres USA is offline
Old 04-05-2012, 10:44 AM
  #968
really, so the fact the carbon shock mounts give a steeper angle is just for looks LOL
Cartman is offline
Old 04-05-2012, 05:53 PM
  #969
That's y I just bought the complete upgrade kit for the rest improvement. I've found:
- narrower upper front arm
- narrower lower front arm
- so the king pin clearance wider, the steering block won't hit the lower arm and create wider steering angle
- the clutch is very light weight, the incline angle of the bell now is same as Mugen/ Serpent, I think the clutch is more powerful then before.
beebone is offline
Old 04-06-2012, 03:23 AM
  #970
Jamison R's Avatar
What is the part # for the update?
Old 04-06-2012, 01:50 PM
  #971
340900
beebone is offline
Old 04-07-2012, 09:11 AM
  #972
Just test the 2012 today, although still break-in new engine, i can feel the dfference between 2011. Very response on chicane and stable.
L and R are perfect balance.
Attached Thumbnails Xray RX8 1/8th Scale-photo.jpg
beebone is offline
Old 04-07-2012, 07:03 PM
  #973
How much shorter are the front A arms, upper and lower
CFowler is offline
Old 04-07-2012, 10:00 PM
  #974
More than 3 mm shorter on front, same length on rear but the shock mount going higher to reduce shock travel
beebone is offline
Old 04-08-2012, 03:59 PM
  #975
Hi,
Will be buying the 2012 upgrade. Does anyone know if the new clutch works? Or is it as bad as the first? Had big problems with it not engaging and the clutch spring self tightening half way through a heat?
xray man is offline
