Xray RX8 1/8th Scale
#481
Hmmmm..... I could start a clutch shoe running in bussines
#485
#489
No, dunno why. I suspect the end play problem, the instruction said 0.7~1mm end play. I think its too squeezy inside the clutch bell, the end play shim+big bearing + 1mm shim + small bearing, put all together than cover the clutch bell.
#490
1st Gear one way problem
Anyone has the 1st gear one way frequently stuck?
Just stuck a new one bought yesterday, this is the 3rd one. T________T
#492
I turn on the engine for the first time yesterday just to see the clutch engagement on the starter box.The engine screws (up an down) started to loosen ..one threw away.I tried them without thread lock but....I think I must use plenty thread lock...
#493
For the hard even more worse because the length is shorter.
Now i'm using Mugen hard spring, no thread lose problem.
#495
