carbon fiber chassis
i'm looking for a corbon fiber chassis for my tc3 but i cant find one anywhere?
109 is a little more than i was likeing to spend but i'll see how seriouse i get with this rc thing and maybe i'll get it at a later date, thanks!
I would just get a:
Yokomo SD
HPI PRO4
Tamiya evo1,2,3,4
If you must swap your chassis consider:
http://www.members.kingston.net/rwdesign/
Yokomo SD
HPI PRO4
Tamiya evo1,2,3,4
price
awolsoldier/wagonman72
Bro just want to ask are these manufacturer different?. They both do produce/manufacture carbon fibre chassis for TC3 w/c one will be the best?. What are the difference between these two manufacturer.. Just asking and no offense....
In my experiences the BMI tweaks too easily but you can always request them to make your top deck 3mm instead of their standard 2mm for a stiffer car
kh15:
Hi,
check the prices on the Warpspeed, IRS, Extreme graphite chassis.
the B.M.I. is cheaper than of the above.
Black Kat:
Hi,
as for the B.M.I. chassis tweaking we run both the 2mm and 3mm top plates on carpet with no tweaking problems. we run the 3mm top plate in mod (7x2-8x1's) and either the 2mm or 3mm in stock. (depending on the bite on the track).
Wency:
Hi,
All B.M.I. chassis are cut from a three way weaved graphite. this makes for a stiffer chassis and top plate. also there are different colors available. the chassis need very little prep before you can race it (usally just Ca the edges). Costomer support is great. any questions are answered quickly. any problems are handled fast.
The Warpspeed chassis is cut from the standard double weave and seems to be more flexy. I never liked mine in mod on high bite carpet. also it needs alot of chasis prep to get it ready to race. I payed ALOT more for the Warpspeed chassis than I did for my B.M.I. chassis with both top plates.
Hi,
Black Kat:
Hi,
Wency:
Hi,
Wency
I have seen a BMI Xray here, I must say the quality is also superb!
(it's the fault of all those metal pipes, post and railings--- they were not looking and had no time to move! )
kh15: its your call what CF chassis you like, there is also one by Penguin RC.
If i were you, ask around who has one, and compare what they have to say to get an UN-biased opinion.
but if you ask me..........
WarpSpeed Racing!!!
OK.. Tnx guys .. That clear things out...
IMHO (running CF chassis on carpet) the IRS w/Tinity Aluminum corner braces seems to be a great combo. NEVER had a tweak problem. No flexing problems.
